Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Problem installing SweetHome on a site |
| Print at Sep 6, 2026, 9:22:16 AM | |
| Posted by crobusa at Apr 4, 2011, 10:37:04 PM |
Problem installing SweetHome on a site I read the FAQ, I swear ;) We're trying to install onto a 64bit environment, and trying to compile an applet. I Can you make any suggestions on how to set up the environment? Thanks, Charles Feb 16, 2011 2:32:54 PM javax.media.j3d.NativePipeline getSupportedOglVendor |
| Posted by Puybaret at Apr 5, 2011, 10:53:26 AM |
Re: Problem installing SweetHome on a site I read the FAQ, I swear ;) You could have read it twice, and would still not have found the answer there! Maybe, I should have an entry there about deploying Sweet Home 3D applet, but it would be probably more interesting to write a separate documentation. The error you reported happened because the applet didn't find the OpenGL j3dcore-ogl-chk.dll automatically extracted from the java3d.jar under Windows 32 bits. You should check that the file windows/i386/java3d.jar file is accessible from the applet through the codebase setting you set. You probably changed the relative or absolute location of SweetHome3DApplet.jar file but didn't update the location of windows/i386/java3d.jar file accordingly. If you still have problems, please copy here the HTML script or Javascript you use to run the applet. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by crobusa at Apr 29, 2011, 2:51:34 AM |
Re: Problem installing SweetHome on a site Our developer is still having issues setting up Eclipse and is getting a bit frustrated. We were able to get past the above issue and self-sign, but doesn't think Eclipse is building a new version.I would really love to setup a GotoMeeting where someone experienced with the web version can walk us through getting an applet compiled and installed on our website in exchange for $75. We're in US Central Time, and aren't afraid of getting up very early in the morning, if necessary to get this done. Thanks! Charles |
| Posted by Puybaret at Apr 29, 2011, 2:40:17 PM |
Re: Problem installing SweetHome on a site I'm Emmanuel Puybaret, the developer of Sweet Home 3D. If you need help, you may write to me even if I'd rather supply support on the forum, so every one could benefit from our discussion. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 6, 2026, 9:22:16 AM |
