Print at Sep 22, 2026, 12:27:18 AM
Posted by db4tech at Mar 12, 2011, 9:29:21 PM
smile   Gallery Space
Hi All,
It's been a long time, hope this post finds everyone well!
Still very busy with degree course work. Just popped on to share some pictures from my gallery model.
With being so busy, I have not had chance to move to Sweet Home version 3. So all renders are with Sweet Home 2.6 + a custom version of AdvancedRendering (version 1.6.2)
Firstly, some of my photographs used for reference.
Next, Sweet Home 3D renders. smile
Entrance view
Top of the stairs
Gallery space
Best wishes,
David Black
(db4tech)
Posted by pencilart at Mar 12, 2011, 9:40:19 PM
Re: Gallery Space
Excellent renderings! Beautiful detail!
How did you do the top of the windows?
Posted by Puybaret at Mar 12, 2011, 11:21:26 PM
Re: Gallery Space
Wahou! smile
Very nicely done. You must be happy to have learnt how to modify the rendering settings! wink
Posted by db4tech at Mar 12, 2011, 11:32:13 PM
Re: Gallery Space
Hi pencilart,
Thank you for your kind words. smile
I modeled just about everything in Art of Illusion, then imported the models into Sweet Home.
Each (main gallery) arched window is made up of 22 parts, 21 parts forming the main window, then a separate custom made arch fill, for the top.
Hope that answers your question.
Thank you,
David
Posted by db4tech at Mar 13, 2011, 12:14:42 AM
Re: Gallery Space
Wahou! smile
Hi Emmanuel,
Thank you kindly. smile
As for the render settings. Oh, it's just a few tweaks! wink
Best wishes,
David
Posted by Puybaret at Mar 13, 2011, 11:56:44 AM
Re: Gallery Space
If one day, you have a little spare time, I would be happy to know if you succeed to get images as nice as the ones you posted with the current version of Sweet Home 3D.
Posted by 2trickpony at Mar 13, 2011, 9:04:55 PM
Re: Gallery Space
Absolutely fantastic!
Well done.
Posted by db4tech at Mar 25, 2011, 5:38:29 PM
Re: Gallery Space
Hi Emmanuel,
First chance I have had to reply to messages.
I will certainly have a go, most likely in a 1.5 to 2 months from now, once all degree work is finished.
Are the light levels in version 3, the same as the online beta version of 3 I tested last October?
Best wishes,
David
Posted by db4tech at Mar 25, 2011, 5:40:33 PM
Re: Gallery Space
Hi 2trickpony,
Well done.
Best wishes,
David
Posted by Puybaret at Mar 28, 2011, 2:31:04 PM
Re: Gallery Space
Yes, I didn't change them. I still don't know why you wanted a higher maximum value.
Posted by db4tech at Apr 2, 2011, 6:42:28 PM
Re: Gallery Space
The light intensity is used to add more photo-realism. The blown out light at the windows.
There is a work around, without you changing your settings, or affecting other peoples models, will come back to this after degree work is finished and I have had chance to see how the lighting looks with version 3.
David
Posted by db4tech at May 23, 2011, 12:07:24 AM
Re: Gallery Space
Hi Emmanuel,
All degree work completed.
Can now have a look at lighting my "Gallery space" scene in Sweet Home 3D version 3.2 so you have a direct comparison to the previous 2.4 renders.
Looking forward to trying this! smile
Thanks,
David
Posted by db4tech at Jun 1, 2011, 9:28:23 PM
Re: Gallery Space
Welcome to June everyone! smile
Produced these renders a few days ago but then waited to post them, didn't want to look like I was trying to take the limelight away from makouillex's gallery post.
Sweet Home 3.2 renders
Imported my "Gallery space" model into Sweet Home 3.2, tried a quick internal (Create photo...) render, to see how things might look before making any lighting changes.
Initial observations, the AO (Ambient Occlusion) levels are quite high, even for midday. If there are no actual black objects in a scene, then no dark areas are rendered anywhere in a scene, producing a flatter none punchy looking rendered image.
Next
Added a power setting to the original lights. At which point I realised that any objects I had added a texture to, needed to have the (new to me) objects "Shininess" setting changed. Also, discovered any older light bulbs size is ignored, so all shadows are hard even if the lamp size is large (notice the multiple hard edge shadows next to the wall light).
Then
Replaced all lamps (there are lots in the scene), with new versions that work correctly in 3.2, tweaked lamp power settings to reach an almost identical output to my previous renders. Spotted another couple of objects that still required their "Shininess" setting altering.
Finally
Needed to added extra light to the gallery window (through the doorway), to try and recreate the blown out photo realistic look of the original renders, a single light on full intensity in 3.2 is not powerful enough to provide enough light to do this.
The extra light also adds a nice reflection on the wooden floor.
Okay I know I am a bit late to the party but...
Main thing I find really problematic with 3.2
The lights disappearing from the 3D preview when not selected.
Trying to visually adjust one lights placement in the 3D preview, while comparing it to other adjacent lights is now impossible. sad
Position a light, then moving virtual position to see that the light is in the correct place, means constantly re-clicking the light to make it re-appear in the 3D preview.
Things I really like about 3.2
Ability to create round walls.
Being able to store viewpoints, a great time saver when moving around within a scene while editing objects, before returning to the render position, very useful, thank you Emmanuel for adding it! smile
Light bulbs "Keep proportions" being locked.
Fast render speed! smile
Thank you,
David
Edit: corrected the text size show on renders.
Posted by Puybaret at Jun 2, 2011, 1:10:22 PM
Re: Gallery Space
Thank you David for your detailed feedback. smile
I'm glad that you succeeded to get a rendering with version 3.2 similar to your version of the Advanced rendering plugin (and faster if I follow you correctly).
I know you would prefer light sources that are always shown in the 3D view. If you really want such lights, I (or you) can prepare a furniture library file containing them. Just have to use a 3D model based on lightSource.obj with the g line that doesn't start with sweethome3d_light_source and use a properties file defining the light sources similar to the ones in DefaultFurnitureCatalog.properties (note the new deformable#, texturable# and lightSourceDiameter# properties introduced in version 3).
Posted by db4tech at Jun 8, 2011, 8:28:18 PM
Re: Gallery Space
Hi Emmanuel,
Couldn't reply sooner been unwell for a few days.
Thank you for the information and lightSource.obj.
I had discovered the deformable#, texturable# and lightSourceDiameter# properties and had already added them to the AdvancedRenderingLights that I used in the above 3.2 renders, to help make sure the lights closely matched the previous renders.
One question, if the light object doesn't start with sweethome3d_light_source, won't it then show in the SunFlow render? sad
As for render times, yes you guessed correctly!
The first "Gallery space" renders (very high resolution) I tried were with a custom AdvancedRendering version, it used twice as many samples (I was aiming for very high quality) and took a massive 51 hours. sad
Then, after returning the samples back to the previous settings, the render was around 23 hours.
After discovering a bug with SunFlow, that drastically affected indoor render times if sunsky or IBL isn't required, I made a new custom AdvnacedRendering version just for this model with that disabled, which rendered the same scene in 13.5 hours. smile
I was very pleasantly surprised to find Sweet Home 3.2 rendered the scene in around 5-6 hours, well done! smile
Have downloaded the source code, look forward to examining the changes you made.
Thank you,
David
Posted by Puybaret at Jun 9, 2011, 10:26:32 AM
Re: Gallery Space
Yes, only the 3D parts starting with sweethome3d_light are invisible when the object it belongs to isn't selected, and the photo renderer works on a copy of the home where everything is unselected.
Sorry for my misleading previous message, but great to learn that optimization on the rendering parameters brought you such a faster processing. Did you downscale the image you published here, or is it full scale?
Posted by db4tech at Jun 9, 2011, 11:46:44 PM
Re: Gallery Space
Yes, the renders are 4000x3000 smile
I've been thinking today about the Sweet Home 3D render name but that's something for another thread.
Thank you,
David
