Print at Sep 20, 2026, 5:07:52 PM View all posts in this thread on one page
Posted by deverne at Feb 21, 2011, 11:21:26 PM
projection of room walls on a 2D plan
Hello,
I'm a newbie to Sweet Home 3D and a new Java developer.
I work on house plan with Sweet Home 3D which is a very nice application.
I need to generate 2D plan of the wall from the 3D model. I read at the SH3D API which is very well documented and try for one week to generate a SVG file containing the projection of the wall.
Today, the result is not as good as expected. I encounter the following issues:
- Unable to locate the door and windows on the wall and draw them at the right place.
- Unable to detect precisely which room is behind a given wall. What is the way to do that?
- Look's like sometimes the room boundary points are in clockwise order, and sometime in anticlockwise. So I suspect that some of my rooms are drawn in reverse order...
- Difficult to remove the very little walls generating when a door is encountered in a wall. Like in the following draw:
Before:
Wall 1 Wall 5
-------+ Wall 3 +---------
W2 +-----------+ W4
After:
Wall 1
The code is available for every one. Where should I sent it? Just ask it ?
The obtained plans are very useful to prepare the future quotations...
Thanks for your help,
Deverne
Posted by hansmex at Feb 21, 2011, 11:42:59 PM
Re: projection of room walls on a 2D plan
Deverne,
I can't follow what you're trying to explain, and it's not because of my English...
If you share your SH3D file, maybe that would explain some things. You can also share a Java file, maybe someone else understands that (but not me).
1 - The command Plan --> Export to SVG format produces an SVG file with a high quality 2D plan, but I guess that's not what you want? Do you need a cross-section? Can you give an example of what you need? Some image from Google Images maybe?
2 - I tried drawing a few rooms in all kinds of orders: clockwise, counterclockwise, random direction walls. When I inspect the inserted rooms with the AdvancedEdit plug-in, all room points are given in clockwise order, so that doesn't confirm your suspicion, although the plug-in may sort room points in that order.
Posted by Puybaret at Feb 22, 2011, 10:01:31 AM
Deverne,
I'm not sure to fully understand what kind of projection you're trying to build, and for which purpose.
A drawing is sometimes much more helpful than any word.
If you're trying to create a parallel projection, using Java 3D parallel projection should help you to get a result much faster (but you won't get an SVG output).
You can upload your code anywhere and add a link to it here.
Posted by deverne at Feb 22, 2011, 10:17:28 PM
Hello Hansmex and Puybaret,
Thanks for your quick reply. I wrote a blog entry at Deverne Blog explaining more precisely what I try to do.
What I want is a SVG file containing: What I want
The code I wrote is:
RoomWalls.zip
The result I obtain is:
Current version
Deverne
Posted by Jerry2012 at Dec 27, 2012, 11:15:13 PM
are there any news on this topic, this wall projection tool would be perfect to use.
Did someone finish it?
best regards, Jerry
