Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: wall select problem |
| Print at Sep 6, 2026, 11:49:39 AM | View all posts in this thread on one page |
| Posted by geoff3 at Jan 26, 2011, 8:56:42 AM |
wall select problem Hi, I have added a sloping piece of wall on top of an end wall to complete a house eve. I need to adjust its angle and to do that I need to select it. The problem is that the lower base wall is selected each time, how can I differential between the two? |
| Posted by hansmex at Jan 26, 2011, 10:15:04 AM |
Re: wall select problem Geoffrey, You can NOT stack walls. This gives unwanted side-effects. 1 - If you want to make a wall sloping, make it sloping. 2 - If you must have two different parts, make the sloping wall separately, use Tools --> Copy As New Furniture and then place it on top of the wall. Then, the wall isn't a wall anymore, but is converted to a normal furniture object, and those are stackable. This solution requires that you have the plug-in installed. (manual ) 3 - If just the end-section of a longer wall should be sloping, select the wall, then do right-click --> Split walls. Adjust the length of the two sections, then make the end section sloping. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by geoff3 at Jan 27, 2011, 7:45:39 AM |
Re: wall select problem Thanks Hans, for a very clear reply, Split walls at the summit of the eve was the easiest Geoff |
Current timezone is GMT Sep 6, 2026, 11:49:39 AM |
