Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Can't load IA 32bit .dll on a AMD-64bit platform |
| Print at Sep 21, 2026, 3:49:16 PM | View all posts in this thread on one page |
| Posted by Sajmmon at Jan 12, 2011, 4:13:34 PM |
Can't load IA 32bit .dll on a AMD-64bit platform Good afternoon, I was impressed by the ability to use SweetHome applet with its 3D capabilities on variuos platforms (http://www.sweethome3d.com/SweetHome3DOnline.jsp). However I get an UnstatisfiedLinkError exception, when I try to run the applet in 64-bit IE. The applet works fine with with Chrome, Firefox, Opera and 32bit IE on my 64bit Windows7. Is it a known problem? Or should I avoid the newest IE. Kind regards -- Szymon Chojnacki http://www.ipipan.eu/~sch/ |
| Posted by Puybaret at Jan 12, 2011, 5:40:22 PM |
Re: Can't load IA 32bit .dll on a AMD-64bit platform I should probably deliver a 64 bits version for Windows too. You probably use a 64 bits JRE, but could you try if 64 bits IE accepts to run applets with a 32 bits JRE? As I think the Online applet is run in a separate process, I don't know if it would work. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Sajmmon at Jan 12, 2011, 10:49:47 PM |
Re: Can't load IA 32bit .dll on a AMD-64bit platform I uninstalled 64-bit JRE, retained 32-bit JRE and reloaded the applet. It seems that "deployJava.js" forces 64-bit IE to download 64-bit JRE. The applet is deployed with no problems with 32-bit JRE in 32-bit IE and other browsers. This behaviour is specific to 64-bit IE (http://www.java.com/en/download/faq/java_win64bit.xml), which requires 64-bit JRE. Kind Regards |
Current timezone is GMT Sep 21, 2026, 3:49:16 PM |
