Print at Sep 6, 2026, 6:24:11 AM
Posted by Ian108 at Jan 2, 2011, 8:29:03 PM
Loft conversion plan
Hi all
I am new to this forum and to this software. Firstly let me say that although I have only just started using SH3D, I am loving it's intuitive feel.
I would like to design a loft conversion for my home, but as yet I cannot work out the best way to create slopping walls/ceilings. Any help or quick pointers would be most appreciated.
Thanks
Ian
Posted by hansmex at Jan 2, 2011, 9:06:57 PM
Re: Loft conversion plan
Ian,
Check out this file. It should make clear how to do it.
Posted by Ian108 at Jan 4, 2011, 10:03:15 AM
Thank you Hans...that was very helpful :)
Posted by Ian108 at Jan 5, 2011, 4:47:56 PM
Is there a way to create triangle shaped windows?
I have also searched the web, but so far only found triangle widow components for Sketchup. Is there an easy way to convert these?
Posted by hansmex at Jan 5, 2011, 5:09:37 PM
Ian,
Easy? That depends on the definition:
- download any *.skp model
- open it in Sketchup
- export it as a 3D model (*.dae)
(- import it in SH3D)
Now, there's a small problem: you can't insert triangular windows in walls. SH3D assumes windows to be rectangular, and leaves gaps around a triangular window. So, the trick is to make the triangular window square, Depending on the exact form of the window, you can combine it with a few triangles until you have a rectangle. In general this can be done in SH3D. If you need an upside-down triangle, export a normal one, and re-import it, and make sure that you change the orientatien during import.
One you have enclosed your triangular window to make it rectangular:
- export the rectangular window as OBJ file
- import it and check the Door/Window check-box while importing.
You may want to give the triangles the correct colour/texture before importing it, because otherwise everything gets the same colour/texture.
Easy? Well... mmmhhmm... But consider this: how long does it take to teach yourself Blender??
Posted by Ian108 at Jan 6, 2011, 4:13:35 PM
Thanks Hans...I will try that. Not sure I fully understand the info on the triangle window though. I want to insert a triangle window (point at top) into a gable roof wall.
Also seem to be having trouble installing Sketchup. Software downloads and seems to install, but then cannot be found??? No icon, program etc can be found in search. Tried several times...very odd.
Posted by hansmex at Jan 6, 2011, 5:22:18 PM
Ian,
If under Windows, installing Sketchup shouldn't cause any problems.
If under Ubuntu, you should read this message .
If under Mac, I can't help you.
Check out this file. It shows you examples of:
- a triangular window in a wall
- a triangular window in a wall with an extra triangle to fill the gap. Note that SH3D has problems with the texture.
- a triangular window as part of a sloping wall.
I hope this explains how to do what I tried to explain earlier.
Posted by Ian108 at Jan 6, 2011, 6:18:29 PM
Thank you Hans. The picture/example speaks a thousand words. Excellent...the sloping wall example works well and is how I intend to use it.
I am trying to intall Sketchup under windows vista. Tried several more times but still same problem. I take it it is a program and has an icon etc? I have now posted problem to Google SU forum as I cannot find other examples of this problem. I do not get any error messages as others do when install fails.
Posted by tmariga at Jul 1, 2021, 8:45:30 PM
Is there a way to create a dome? For residential
Posted by hansmex at Jul 2, 2021, 12:59:21 AM
No, check the Trimble SketchUp Warehouse...
