Print at Sep 6, 2026, 11:41:53 AM
Posted by Bucky at Nov 25, 2010, 4:57:40 AM
Sweet Home 3D Viewer
Following the directions, I cannot seem to get the HTML 3D Viewer to work.
I am setting it up on a local Mac Apache2 server in preparation for uploading to an Apacher2 server on Linux.
The error I get is "Applet com.eteks.sweethome3d.applet.SweetHome3DViewer notinited". To me, this seems that my html cannot find an applet at eteks.com. Hmmm? But then, I don't speak JAVA.
I'm running OS 10.5.8 and apparently Java Plug-in 1.5.0_26, Using JRE version 1.5.0_26-b03-376-9M3263 Java HotSpot(TM) Client VM.
The Console reports the following:
MRJ Plugin for Mac OS X v1.0.1
[starting up Java Applet Security @ Wed Nov 24 18:35:10 MST 2010]
load: class com.eteks.sweethome3d.applet.SweetHome3DViewer not found.
java.lang.ClassNotFoundException: com.eteks.sweethome3d.applet.SweetHome3DViewer
at sun.applet.AppletClassLoader.findClass(AppletClassLoader.java:181)
at java.lang.ClassLoader.loadClass(ClassLoader.java:317)
at sun.applet.AppletClassLoader.loadClass(AppletClassLoader.java:145)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at sun.applet.AppletClassLoader.loadCode(AppletClassLoader.java:667)
at sun.applet.AppletPanel.createApplet(AppletPanel.java:786)
at sun.plugin.AppletViewer.createApplet(AppletViewer.java:1873)
at jep.AppletFramePanel.createApplet(Unknown Source)
at sun.applet.AppletPanel.runLoader(AppletPanel.java:715)
at sun.applet.AppletPanel.run(AppletPanel.java:369)
at jep.AppletFramePanel.run(Unknown Source)
at java.lang.Thread.run(Thread.java:655)
Finalize objects on finalization queue� completed.
Memory: 3,056K Free: 531K (17%)� completed.
Memory: 3,056K Free: 411K (13%)� completed.
Any help in solving this problem would be greatly appreciated. If I can provide more information, please let me know what it is.
I am hoping to share my meager designs with some family members.
Bucky
Posted by Puybaret at Dec 4, 2010, 12:47:34 PM
Re: Sweet Home 3D Viewer
You probably didn't put the jar files on the server or not at the right place.
Does it work in your local folder?
An other tip: don't forget to quit your browser between two changes to be sure that it takes into account the changes you made.
