Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: furniture library |
| Print at Jul 27, 2026, 7:21:03 AM | |
| Posted by abelorusov at Nov 13, 2010, 2:27:17 AM |
furniture library Hello: I imported a few furniture pieces, not a library. I modified them a little. I see these pieces in the top left box of the screen. How can I copy these pieces and give to a friend? thanks |
| Posted by fhoofman at Nov 13, 2010, 2:34:16 AM |
Re: furniture library I don't see anything |
| Posted by hansmex at Nov 13, 2010, 2:38:04 AM |
Re: furniture library Alexey, - In your design, select the model that you want to share with a friend. - Now do CTRL-C to copy it. - Start a new instance of SH3D - Copy your model in this new, empty SH3D with CTRL-V - Now, in the menu click 3D view --> Export to OBJ format - A new window opens, where you can choose a directory, and give the model a name - Two files are created: modelname.obj and modelname.mtl - Give both files to your friend - He/she can use the model after importing it with Furniture --> Import furniture If you want, you can compress the two files into a zip-file, which also can be directly imported the same way. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by abelorusov at Nov 13, 2010, 2:48:26 AM |
Re: furniture library Thanks, Hansmex. It is a great solution but it looks like it works only for one piece of furniture. How do I give a friend 20 new items? How can i create a furniture library? |
| Posted by hansmex at Nov 13, 2010, 2:53:05 AM |
Re: furniture library Alexey, - Read the plug-in manual - Install the plug-in ExportToSH3F - Export all imported models in one file Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by abelorusov at Nov 13, 2010, 3:04:37 AM |
Re: furniture library thank you very much |
Current timezone is GMT Jul 27, 2026, 7:21:03 AM |
