Print at Sep 21, 2026, 12:47:09 AM
Posted by charankalcut at Oct 19, 2010, 9:14:56 AM
How To Fix Walls
Hi all! Is there any way to fix the walls so that nobody can resize
the walls?
Thanks is advance
Posted by hansmex at Oct 19, 2010, 11:52:50 AM
Re: How To Fix Walls
Charanjeet,
That depends on what you want EXACTLY.
1 - Fix walls so they won't be accidentally deleted: use Plan --> Lock base plan
2 - Fix walls so users can change the entire plan, but not the walls: not possible
3 - Allow users to view the model without changing anything: use the viewer
There is, however, a workaround.
- Install the plug-in CopyAsNewFurniture (see tutorial )
- Make your design with walls, floors and roofs, and save it.
- Insert at least ONE piece of furniture (doors and windows also count as furniture)
- Use Tools --> Copy as new furniture to copy your design.
- Open a new instance of SH3D and paste your new furniture into it.
- Use this fixed model to make the rest of your design.
Good luck
