Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Hommage to Light |
| Print at Sep 20, 2026, 4:05:36 AM | |
| Posted by hansmex at Oct 11, 2010, 1:47:52 AM |
Hommage to Light Hello all :-) To honour all the hard work of David, Frederic and Emmanuel to make the excellent Advanced Render plug-in (and function in version 3.0) I would like to share this "Hommage to Light" :-) Hans ![]() ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by fhoofman at Oct 12, 2010, 4:46:33 AM |
Re: Hommage to Light I like the colorful hall way ceiling |
| Posted by PtiNounours at Oct 12, 2010, 1:46:30 PM |
Re: Hommage to Light Google translate: The most beautiful effect. It was done with SweetHome3D? Would be possible for you to send your file SH3D, so I study how you did this achievement? Finally, congratulations to the staff for the excellent Render of the version 3.0 |
| Posted by hansmex at Oct 12, 2010, 2:24:34 PM |
Re: Hommage to Light Sebastien, Unfortunately I can't send you the original file. SH3D crashed or something and the file was damaged in such a way that it could not be recovered. Therefore I couldn't submit it for the contest, so I decided to show it here. How was it done? Basically it is very, very simple. Two parallel walls with floor and ceiling, everything white or very light gray. The ceiling has fins, or blades of approx 50 cms high, spaced 50 or so cms apart. Between the blades I placed approx. 150 light bulbs carefully tuned to produce this effect. Because of the large number of lights, each rendering took quite a long time. That's how I did it in a nutshell. Hans EDIT: Taken away French translation ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by PtiNounours at Oct 12, 2010, 8:23:31 PM |
Re: Hommage to Light ok, thanks Hans. I will test soon. |
| Posted by db4tech at Oct 14, 2010, 11:45:38 PM |
Re: Hommage to Light I like it Hans, thank you! ![]() It must have taken ages to render? Good work on the plug-ins pdf by the way. (in connection with that, I've sent you a little e-mail) db4tech |
| Posted by hansmex at Oct 15, 2010, 12:01:18 AM |
Re: Hommage to Light db4tech, Glad you liked it. Yep, rendering took a lot of time, especially the last big ones. Looking forward to your email (hasn't arrived yet). There's bound to be some mistakes and omissions in version 1.0 of the plug-in manual. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by maker at Oct 15, 2010, 1:00:36 PM |
Re: Hommage to Light Truly poetic. Thanks for sharing. The music of silence? ![]() |
Current timezone is GMT Sep 20, 2026, 4:05:36 AM |
