Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Dimensions of the Open door in 3D view |
| Print at Sep 14, 2026, 12:22:19 AM | |
| Posted by jmd at Sep 16, 2010, 7:38:48 PM |
Dimensions of the Open door in 3D view Hello from France I'm talking about the "open door" you can see open in the 3d view. It seems to be 1.8 meter wide open and I cannot resize the lenth of the door. any idea ? many thanks |
| Posted by maker at Sep 16, 2010, 9:51:22 PM |
Re: Dimensions of the Open door in 3D view Dbl-click on the door (in Plan View). Make changes as wished... Doesn't that work for you? You cannot make changes in the 3d view (Just in case you're trying that ;-) |
| Posted by jmd at Sep 17, 2010, 2:49:01 PM |
Re: Dimensions of the Open door in 3D view Thanks, but it does not work on my computer I just foud the solution : - create an open door but do not slide it on a wall, let it in the middle of the room ! - then resize it (it works) - then slide it on the wall with the arrows of the keyboard, NOT with the mouse ! I'm done. Have a nice day. |
| Posted by Puybaret at Sep 18, 2010, 11:57:48 AM |
Re: Dimensions of the Open door in 3D view You could also use the shift key (or disable magnetism in the preferences) when you drop the door on the wall. See also this message. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by jmd at Sep 19, 2010, 10:17:32 AM |
Re: Dimensions of the Open door in 3D view OK, strange behavior of the open door now we have 2 solutions and I've discovered magnetism in Sweethome3D thanks |
Current timezone is GMT Sep 14, 2026, 12:22:19 AM |
