Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Driver problems |
| Print at Oct 15, 2026, 5:04:24 PM | |
| Posted by pencilart at Sep 10, 2010, 9:44:25 PM |
Driver problems I'm running SuSE 11.2 and I have NVidia's driver installed. Recently I accepted an update for xorg. This is from the zypp log: Now my SweetHome3D app won't start! It says: "Fatal error in 3D rendering system. Update DirectX Opengl drivers of your computer graphics card." I don't think there are any updates for this (at least not yet) Is there someway to run SH3D anyway? Art Of Illusion has no problem starting and running despite the xorg update. I'm very sad. Now I cannot check how my latest model (a new version of the sink) might look or if it would work. :( |
| Posted by hansmex at Sep 10, 2010, 11:02:04 PM |
Re: Driver problems Pencilar: ?Use Ubuntu? Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by pencilart at Sep 11, 2010, 1:48:24 AM |
Re: Driver problemsok, I tried SH3D in a terminal and this is what I got: Java was also updated from the system updater too. I'm wondering if that had anything to do with it? Anyway, I didn't change my video driver - it's the same one (from NVidia) that successfully ran SH3D 2.6 a couple of days ago. Like I said, I'm running SuSE 11.2 and SH3D ran fine without problems before these system updates. P.S. I tried a rendering from Art Of Illusion and it starts up and renders just fine. I've also tried to run Extreme Tux Racer but that won't start. Same problem as SH3D I'm afraid: |
| Posted by Puybaret at Sep 11, 2010, 12:53:00 PM |
Re: Driver problems Generally, the warning doesn't prevent you from running Sweet Home 3D (I've got the same warning under Ubuntu 8). I read in a French forum that sometimes it fails because of the Java version you use (OpenJDK or SunJDK). How do you run Sweet Home 3D? From its installer or the Java Web Start link? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by pencilart at Sep 12, 2010, 9:48:56 PM |
Re: Driver problems From the installer like this: /home/<username>/SH3D/SweetHome3D-2.6/SweetHome3D And it won't run, it just shuts down. :( I just tried it from the webstart method and I get the same results, "Fatal error" and it exits. I do have Sun's java installed. I reported the problem on the OpenSuSE forum and was told to try reinstalling the video driver (http://forums.opensuse.org/english/get-help-h...ined-app.html#post2220727) So I am hoping that will do the trick. |
| Posted by pencilart at Sep 12, 2010, 11:12:00 PM |
Re: Driver problems ok, I did as they told me, to reinstall the driver and it worked! SH3D started right up and ran. I'm back in business! ^_^ :D |
| Posted by Puybaret at Sep 12, 2010, 11:29:12 PM |
Re: Driver problems Great to hear that! You won't have to try Ubuntu yet! ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by pencilart at Sep 12, 2010, 11:35:21 PM |
Re: Driver problems :laughing: |
Current timezone is GMT Oct 15, 2026, 5:04:24 PM |
