Print at Jul 28, 2026, 8:04:19 PM
Posted by fhoofman at Aug 11, 2010, 8:52:20 PM
advanced photo stop renderring
i'm using create advanced photo and the render always stops at light I put.
here's the image:
http://www.4shared.com/photo/TYRDZCHh/2_online.html
I also attach the file
http://www.4shared.com/file/_BKWgpwS/3_online.html
is there anybody can help me why the render is stop?
Posted by hansmex at Aug 11, 2010, 11:06:37 PM
Re: advanced photo stop renderring
Yudi:
I had a look at your model and noticed a few things.
1 - When rendering "fast" there was no problem, only when using "best".
2 - The "Schneider" sign doesn't render correctly on my computer (Ubuntu with SH3D 2.5): The sign is black and the lettering is black as well. The letters are visible because they have a speckled edge. This suggests to me that you used a GIF as texture and that there is a (slight?) problem with the transparency.
3 - When making all walls and all furniture white, your model rendered without a problem using the "best" setting.
There have been some reports that there is a problem using large size textures. I also read that it is preferable to have textures with sizes that are a multiple of 2, e.g. 512x512 or 128x256 pixels.
You may try to change some of your textures and see if this solves your problem.
Posted by Puybaret at Aug 12, 2010, 11:21:58 AM
There's still a problem in version 2.5 with some furniture models when they contain huge texture coordinates. I fixed it in the current beta. As the beta version can't run the advanced photo plug-in, please check if the bug is fixed by creating a photo with the best quality option.
Posted by fhoofman at Aug 12, 2010, 2:09:43 PM
I don't think it's just the texture.
This also happens when I render a high resolution
take a look at
http://www.4shared.com/photo/HnKqWT9w/5_online.html
http://www.4shared.com/file/cmNZJzMt/4_online.html
Posted by hansmex at Aug 12, 2010, 10:51:27 PM
Yudi:
I did a few more tests on your design. Here are the results:
1 - I started with version 2.5 and used the "normal" advanced plug-in (not Phong or Uber). Picture size reduced to 400x212 pixels. All renders with view set to "virtual visitor".
1a - First I tried your file as downloaded, setting "fast". Result is that the render did NOT finish. Therefor, I did not try with setting "best".
1b - I changed all walls and all furniture to white, so I can see whether the problem lies with a texture or with a model. With everything set to white, the model rendered without problem, as you can see below.
1c - There are a lot of small black spots in the render. I'm not sure what causes these spots, but I think there has been a post about this "unwanted feature".
25-adv-best
2 - Reading Emmanuel's comment, I also did a few renders with version 2.6, the standard "create photo" setting, size 400x212 pixels, virtual visitor.
2a - Without changing walls or furniture the render completed without any problem, as you can see below.
26-best
Conclusion:
a - Indeed, version 2.6 seems to solve a few problems with textures. As soon as there will be a "real" 2.6 (or 2.7 or 2.8) you can use that version to make high quality renders using the plug-ins.
b - As long as you have to use version 2.5 you will have to investigate which texture(s) is(are) causing the problem(s).
Posted by fhoofman at Aug 12, 2010, 11:13:11 PM
thank you Hans, you do me a great favor
i'll wait for the final version of 2.6 :)
