Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: "Print to PDF" doesn't work on my portable version? |
| Print at Sep 26, 2026, 3:29:14 PM | View all posts in this thread on one page |
| Posted by Dirki at Aug 10, 2010, 3:40:04 PM |
"Print to PDF" doesn't work on my portable version? When I click in the menu "File" Print to PDF" there are created none working 0 bytes PDF files. What can I do to create working PDF files? When I click on an icon like "Create walls" a message appears: "Create walls tip". Activating the check box let it pop up again after the next program start. How can I avoid this? ---------------------------------------- Actual (none Beta) stable, portable Sweet Home 3D Windows 7 Premium Home Edition & Vista |
| Posted by Puybaret at Aug 11, 2010, 12:08:58 AM |
Re: "Print to PDF" doesn't work on my portable version? When I click on an icon like "Create walls" a message appears: "Create walls tip". Activating the check box let it pop up again after the next program start. How can I avoid this? Until now, portable versions are built by other people and you probably picked up a buggy one unable to record preferences. Please try an other distribution.By the way, once you found a portable version that works, it would be nice to report it here (you can report also the ones that failed). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Dirki at Aug 11, 2010, 12:36:40 AM |
Re: "Print to PDF" doesn't work on my portable version? Thank you Emmanuel, I use this one, it is the only actual portable version I could find: http://www.sweethome3d.eu/support/forum/viewt...39EDD926491DCDADF9179268D I assume, according the none working PDF function it is the same answer. Thanks again, nice greetings, Dirk ---------------------------------------- Actual (none Beta) stable, portable Sweet Home 3D Windows 7 Premium Home Edition & Vista |
Current timezone is GMT Sep 26, 2026, 3:29:14 PM |
