Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to make a roof light and a corner sink? |
| Print at Sep 26, 2026, 5:48:04 PM | View all posts in this thread on one page |
| Posted by Dirki at Aug 5, 2010, 12:54:51 AM |
How to make a roof light and a corner sink? How can I make / use a horizontal roof light and a corner sink (from corner to both sides 90 cm)? ---------------------------------------- Actual (none Beta) stable, portable Sweet Home 3D Windows 7 Premium Home Edition & Vista |
| Posted by Puybaret at Aug 5, 2010, 12:45:39 PM |
Re: How to make a roof light and a corner sink? Lights can be only point lights until now. You'll have to build the corner sink from a basic sink that you'll surround with triangle and boxes, or probably better with an other program like AOI or Blender. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Dirki at Aug 5, 2010, 1:42:40 PM |
Re: How to make a roof light and a corner sink? Thank you Emmanuel, Okay, doesn't seem to be that easy... Thanks again, nice greetings, Dirk ---------------------------------------- Actual (none Beta) stable, portable Sweet Home 3D Windows 7 Premium Home Edition & Vista |
| Posted by maker at Aug 5, 2010, 3:20:21 PM |
Re: How to make a roof light and a corner sink? Alternative suggestions: 1.You can add multiple lights in an array to simulate the roof-light. 2.You can use poseray ( http://mysite.verizon.net/sfg0000/ ), import OBJ files.Then convert your light to "array" and use povray renderer (povray.org) to render. 3. Import OBJ in Kerkythea (www.kerkythea.net), replace lights/materials as needed, render. Hope this helps (at least a little bit ;) ) |
| Posted by Dirki at Aug 7, 2010, 2:06:31 AM |
Re: How to make a roof light and a corner sink? Many thanks maker, Yes, of course, it helps. I will try... Many thanks again, above all for the links. Nice greetings, Dirk ---------------------------------------- Actual (none Beta) stable, portable Sweet Home 3D Windows 7 Premium Home Edition & Vista |
Current timezone is GMT Sep 26, 2026, 5:48:04 PM |
