Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How can I add different colors to the floor? |
| Print at Sep 27, 2026, 7:47:59 AM |
| Posted by Dirki at Jul 31, 2010, 1:49:19 AM |
How can I add different colors to the floor? How can I add different colors to the same floor? E.g. I want to use 3 colors for the same floor of a room (e.g. for different tiling): white at the side around, blue for a square in the middle and another color somewhere. ---------------------------------------- Actual (none Beta) stable, portable Sweet Home 3D Windows 7 Premium Home Edition & Vista |
| Posted by Dirki at Jul 31, 2010, 1:54:50 AM |
Re: How can I add different colors to the floor? And how can I set to be notified by email receiving replies on my posts? ---------------------------------------- Actual (none Beta) stable, portable Sweet Home 3D Windows 7 Premium Home Edition & Vista |
| Posted by hansmex at Jul 31, 2010, 2:10:56 AM |
Re: How can I add different colors to the floor? Dirki: It is possible to do that. I already wrote a mesage on the forum how you can do it. Unfortunately I can't find that entry now :-( So, you will have to wait until tomorrow, when I'm sober again, and then I will repeat my answer. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by maker at Jul 31, 2010, 12:59:57 PM |
Re: How can I add different colors to the floor? Till hansmex's reply comes, here's two ways I can think of. 1. Make your floor as furniture. Export as obj, re-import. Make your tile design in a paint program, and apply it as texture. 2. If your floor is mostly one colour, with patches of other colours -- Make the floor and add minimum height (0.1 inch) of furniture of required colour and shape above it. Hope this helps |
| Posted by Puybaret at Jul 31, 2010, 1:20:18 PM |
Re: How can I add different colors to the floor? Dirki, there are simpler ways: draw rooms on top of each other (rooms are drawn in the same order they were added), or surrounding each other (it's more difficult to draw but better rendered in the 2D plan). Please see the attached example. One more tip: if you want precise values, enter numeric values with the keyboard by pressing the enter key. ---------------------------------------- ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by maker at Jul 31, 2010, 1:31:23 PM |
Re: How can I add different colors to the floor? Re being notified by email -- you can "watch" certain threads or forums -- in My Profile (top right of page)>>My watch Good luck |
| Posted by hansmex at Jul 31, 2010, 2:00:53 PM |
Re: How can I add different colors to the floor? Dirki, Emmanuel, Maker: Here's my way of doing it. I once posted this solution here, but couldn't find it again. Strange thing is, that for some reason it doesn't work the way it should. Instead of following the space I draw, the floor also fills the middle part. As far as I am concerned, this is an "unwanted feature". The problem with "stacking" floors is that they cause strange behaviour in the rendering window. Hans ---------------------------------------- ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Dirki at Jul 31, 2010, 5:45:51 PM |
Re: How can I add different colors to the floor? Many thanks for your help and files / tests. On my "Sweet Home" I cannot get it to work: DifferentFloorsInTheSameRoom2-try.sh3d test-different-floor-colors.sh3d Where / how can I upload attachments in this forum? Okay, I just try the "watch" option. Thank you very much again, nice greetings, Dirk ---------------------------------------- Actual (none Beta) stable, portable Sweet Home 3D Windows 7 Premium Home Edition & Vista |
| Posted by hansmex at Jul 31, 2010, 7:22:57 PM |
Re: How can I add different colors to the floor? Dirk: I made a few changes in your design . Instead of floors/rooms, I used boxes. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Dirki at Jul 31, 2010, 8:10:31 PM |
Re: How can I add different colors to the floor? Many thanks Hans, Yes, great, that works...I assume to use roundings is not possible (the way using boxes). I will try a bit more... How can I mark a box easiest, which lies under another box or an object and cannot be clicked? Many thanks again. Nice greetings, Dirk ---------------------------------------- Actual (none Beta) stable, portable Sweet Home 3D Windows 7 Premium Home Edition & Vista |
Current timezone is GMT Sep 27, 2026, 7:47:59 AM |
