Print at Sep 27, 2026, 1:57:07 AM
Posted by Dirki at Jul 31, 2010, 1:49:19 AM
How can I add different colors to the floor?
How can I add different colors to the same floor?
E.g. I want to use 3 colors for the same floor of a room (e.g. for different tiling): white at the side around, blue for a square in the middle and another color somewhere.
Actual (none Beta) stable, portable Sweet Home 3D
Windows 7 Premium Home Edition & Vista
Posted by Dirki at Jul 31, 2010, 1:54:50 AM
Re: How can I add different colors to the floor?
And how can I set to be notified by email receiving replies on my posts?
Posted by hansmex at Jul 31, 2010, 2:10:56 AM
Dirki:
It is possible to do that. I already wrote a mesage on the forum how you can do it. Unfortunately I can't find that entry now :-(
So, you will have to wait until tomorrow, when I'm sober again, and then I will repeat my answer.
Posted by maker at Jul 31, 2010, 12:59:57 PM
Till hansmex's reply comes, here's two ways I can think of.
1. Make your floor as furniture. Export as obj, re-import. Make your tile design in a paint program, and apply it as texture.
2. If your floor is mostly one colour, with patches of other colours -- Make the floor and add minimum height (0.1 inch) of furniture of required colour and shape above it.
Hope this helps
Posted by Puybaret at Jul 31, 2010, 1:20:18 PM
Dirki, there are simpler ways: draw rooms on top of each other (rooms are drawn in the same order they were added), or surrounding each other (it's more difficult to draw but better rendered in the 2D plan).
Please see the attached example.
One more tip: if you want precise values, enter numeric values with the keyboard by pressing the enter key.
Attachment DifferentFloorsInTheSameRoom.sh3d (31977 bytes) (Download count: 1254) (Two ways to create different floors in the same room)
Posted by maker at Jul 31, 2010, 1:31:23 PM
Re being notified by email -- you can "watch" certain threads or forums -- in My Profile (top right of page)>>My watch
Good luck
Posted by hansmex at Jul 31, 2010, 2:00:53 PM
Dirki, Emmanuel, Maker:
Here's my way of doing it. I once posted this solution here, but couldn't find it again. Strange thing is, that for some reason it doesn't work the way it should. Instead of following the space I draw, the floor also fills the middle part. As far as I am concerned, this is an "unwanted feature".
The problem with "stacking" floors is that they cause strange behaviour in the rendering window.
Attachment DifferentFloorsInTheSameRoom2.sh3d (391043 bytes) (Download count: 1205)
Posted by Dirki at Jul 31, 2010, 5:45:51 PM
Many thanks for your help and files / tests.
On my "Sweet Home" I cannot get it to work:
DifferentFloorsInTheSameRoom2-try.sh3d
test-different-floor-colors.sh3d
Where / how can I upload attachments in this forum?
Okay, I just try the "watch" option.
Thank you very much again, nice greetings, Dirk
Posted by hansmex at Jul 31, 2010, 7:22:57 PM
Dirk:
I made a few changes in your design . Instead of floors/rooms, I used boxes.
Posted by Dirki at Jul 31, 2010, 8:10:31 PM
Many thanks Hans,
Yes, great, that works...I assume to use roundings is not possible (the way using boxes). I will try a bit more...
How can I mark a box easiest, which lies under another box or an object and cannot be clicked?
Many thanks again. Nice greetings, Dirk
