Print at Jul 28, 2026, 6:58:46 PM
Posted by fhoofman at Jul 25, 2010, 6:25:00 PM
love struck   Bug on open door
I think I found a bug on version 2.5
you can download at:
http://www.mediafire.com/file/dqbg5isgg2tsuz2/2.sh3d
I found that the door is wider than its frame. when I try to resize it, the magnetism is not working.
is there anybody has found it?
thax
Posted by db4tech at Jul 26, 2010, 4:39:53 AM
Re: Bug on open door
Hi fhoofman,
Yes I discovered that one, while I was constructing a very old building, with walls that needed to be 40cm thick (try that wall thickness and see what happens to your door! biggrin ) the only size that works for the open doors at the moment is, Emmanuel's original 7.5cm for walls (It's okay Emmanuel, your secret for not wanting to change the default wall thickness is safe with me! wink)
fhoofman there are two workarounds, either export the door with frame and edit the frame thickness in a program like Art of Illusion then import it again, making sure to tick the door/window tick box while importing.
or
export the door and frame, remove all the frame leaving just the door, import the door as a normal obj, without ticking the door/window tick box. use an empty frame from the furniture list, then correctly position the imported door.
Personally I like the last option because the door can then be set open at whatever angle you like.
Hope this helps!
db4tech
Posted by fhoofman at Aug 24, 2010, 4:00:56 PM
Emmanuel, you forget to update this bug on version 2.6 biggrin
Posted by Puybaret at Aug 24, 2010, 5:47:01 PM
I didn't forget anything and this is more like a complicated enhancement than a bug. wink
Here's an other workaround easier that db4tech's one:
- Add first a Door frame at the place you want while magnetism is active.
- Then add the Open door at the same place with disabled magnetism (press down the shift key to disable temporarily magnetism), using Furniture > Align menu items and arrow keys to help you place it correctly.
- Finally if needed, group the two items to avoid future auto resize.
See the joined example.
Attachment OpenDoorInThickWall.sh3d (23560 bytes) (Download count: 300167) (An open door in a thick wall)
