Print at Aug 17, 2026, 8:05:09 AM
Posted by 32.pauls at Jul 8, 2010, 5:55:00 PM
Error with picture-making
I have a problem with my photo engine to make pictures.It stops in unfinished picture,but it thinks its complecte.
To see the picture,ClIcK HeRe
Thank you!
Posted by 32.pauls at Jul 8, 2010, 6:00:05 PM
Re: Error with picture-making
The link is incorrect.
Corrected version:Click me
Thanks!
To personel replies,e-mail me
Posted by hansmex at Jul 8, 2010, 6:03:46 PM
32.pauls:
It looks like a memory problem to me.
Save your work, close SH3D. Start it again, load your model, and try to render your picture.
Posted by 32.pauls at Jul 8, 2010, 7:04:29 PM
This time it stops and options just allow to Create and Close.But it looks a bit better(few more blocks).
Posted by hansmex at Jul 8, 2010, 9:52:23 PM
32.pauls:
I still think it's a memory problem, caused by the size of your model or the textures it uses. Several things you could try:
1 - reduce the number of textures
2 - reduce the size of the textures, especially if they are bigger than 1000x1000 pixels
3 - reduce overall model size
4 - allow SH3D to use more memory: read this thread. Try 1048 first, before you go higher. It seems too much memory can cause problems as well.
5 - make sure your memory is cleared; if necessary restart your computer before you try a large render.
Posted by db4tech at Jul 9, 2010, 5:02:34 AM
Hi 32.pauls and Hans,
I had the same problem couple of weeks ago, with a scene I was creating. After a process of elimination, discovered that it was caused by one of the furniture items that I had added to a scene.
Hiding or deleting the problem causing furniture item instantly stopped the render problem.
So as another idea it might be worth going through you used items and hiding them one at a time, then try re-rendering.
If it is caused by one of your items, (after mentioning it to Emmanuel) I can tell you there is a fix and the next version of the Advanced render should not have the same problem.
PS: 1024 smile
db4tech
