Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Is there a way to add simple graphics |
| Print at Sep 6, 2026, 8:01:08 AM | |
| Posted by beral at Jun 24, 2010, 11:56:08 PM |
Is there a way to add simple graphics I'm looking for a way to add simple 2D graphics, for example a line, rectangle or circle. I guess for a rectangle I can use a box with minimum height and no fill, but I'd like to be able to draw a circle around a round table and chairs to show the effective boundary of the set (I'm trying to model a church hall set up with round tables for a party, to see how many tables I can get in). All suggestions and work-rounds appreciated! |
| Posted by hansmex at Jun 25, 2010, 1:35:54 AM |
Re: Is there a way to add simple graphics Beral: Here's a workaround. Import this model and make sure its orientation is correct. Combine 4 to make a circle, and use Group , or Export as OBJ, or Export as furniture . You can than give it any height (close to zero) and diameter to indicate the space a round table with chairs occupies. In the same way you could make an object from 4 thin boxes and export/import it to form a square. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 6, 2026, 8:01:08 AM |
