Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Emmanuel is this version more to your liking? |
| Print at Sep 19, 2026, 9:27:40 PM | |
| Posted by db4tech at Jun 23, 2010, 2:44:26 AM |
Emmanuel is this version more to your liking?Hi Emmanuel, I have changed another couple of things, is this version more to your liking? ![]() I have rendered a higher resolution version if you require it. db4tech Edit: Now I've posted it, I think the LCD TV needs to be on a taller cabinet, it looks a bit uncomfortable to watch, when it is that low down. |
| Posted by Puybaret at Jun 23, 2010, 8:59:34 AM |
Re: Emmanuel is this version more to your liking? Very nice! You seem to be gifted to find humans that you can import in Sweet Home 3D. ![]() Would you have a secret tip that you could share with us? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by db4tech at Jun 23, 2010, 7:49:12 PM |
Re: Emmanuel is this version more to your liking? Would you have a secret tip that you could share with us? Only thing is, if I share it, then it will no longer be a secret! The hardest part is trying to get them to sign a model release form. Sigh! http://archive3d.net/ It seems all the people models need to have their texture maps re-applied. I can only guess whoever did the original 3DS conversions didn't check the output results for successful conversion. Some of the people models don't even have any texture maps, while others the body parts have been merged and UV mapping is lost. It is quite a mixed bag, almost like a lucky dip! I have also made some slight modifications to some of the ones I have downloaded and/or removed items from their original downloaded model scene. db4tech Edit: Forgot to mention. I am also trying to learn DAZ studio, so I will have even more control, allowing different poses. |
Current timezone is GMT Sep 19, 2026, 9:27:40 PM |
