Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Furniture Library Editor released |
| Print at Sep 13, 2026, 3:20:51 PM |
| Posted by selden at Jun 9, 2025, 8:45:27 PM |
Re: Furniture Library Editor released No luck: Java complains it doesn't understand the option. (rolls eyes) ---------------------------------------- Selden |
| Posted by Keet at Jun 9, 2025, 8:59:42 PM |
Re: Furniture Library Editor released ... You can't drag a folder in the Furniture Library Editor. You can select multiple OBJ files and/or ZIP files containing OBJ/MTL files and drag&drop those in the FLE window.However, when I tried to drag-and-drop of the directory folder containing the .obj and .mtl files into the main pane of that window, nothing happens but I get this error message in the cli (I'm using cygwin bash) command window: Correction, for the FLE is use an older runtime: 1.7.0_261. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by HeideN at Apr 16, 2026, 7:46:06 AM |
Re: Furniture Library Editor released I finally got the library to open on my old windows 7 but when I try to create a new library I only got one funiture , when I import another it only changes the first one to the new object, I’ve tried the import button and drag and drop ( I can see the import process ) what is I doing wrong? |
Current timezone is GMT Sep 13, 2026, 3:20:51 PM |
