Print at Aug 24, 2026, 9:04:54 AM
Posted by fhoofman at May 21, 2010, 8:11:37 PM
confused   rendering is stop working when i put some light
i have read Advanced rendering plug-in and I tried some light and i want to see how does it look like.
Apparently when i render, it suddenly stop working. is there any way to make it work?
Posted by fhoofman at May 21, 2010, 9:30:17 PM
Re: rendering is stop working when i put some light
I already fix it. horray ...
it appear when you update the plugin render for the first time, you need to restart the program, before you can use it.
if you don't restart the program after installing the basicLights.sh3f, it won't render properly.
Geeez.. I looked stupid
Posted by db4tech at May 21, 2010, 9:52:19 PM
Hi fhoofman,
Now you have tried the basic lights package you might be interested in this update (also contains the original basic lights plus) featuring 8 new coloured lights (approved by Emmanuel)
>>> Here <<<
As mentioned due to a slight renaming convention, it is best to remove the basic lights sh3f file first or you will end up with duplicates.
If you are using version 1.1 of the advanced rendering plug-in you may be interested to see version 1.2 with some great extras
>>> Version 1.2 information <<<
db4tech
Posted by fhoofman at May 21, 2010, 10:37:01 PM
wow.... thanks man.
great upgrade. very nice
