Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Generic European Schuko wall socket – SH3F furniture library |
| Print at Sep 13, 2026, 10:53:24 PM | |
| Posted by horel at Jul 21, 2026, 4:27:41 AM |
Generic European Schuko wall socket – SH3F furniture library This contribution contains a generic European Schuko wall socket as a Sweet Home 3D furniture library. Features: SH3F format White recessed wall socket Dimensions: 8.2 × 8.2 × 1.0 cm Default centre elevation: 130 cm Rotation around the X, Y and Z axes is enabled English and Hungarian catalog texts Includes separate materials for plastic, contacts and socket holes The model was tested in Sweet Home 3D version 7.5. Installation: Double-click the SH3F file or use: Furniture > Import furniture library. License: CC BY 4.0 Attachments: SH3F furniture library Preview image Source files in OBJ / MTL format Electrical_EU_wall_socket_v1.0.sh3f |
| Posted by Keet at Jul 22, 2026, 9:43:31 AM |
Re: Generic European Schuko wall socket – SH3F furniture library Excellent model and a very well formatted furniture library. Just one remark: a few sides have the normals flipped, i.e. you see through them from the outside but they show on the inside. (7.5 on Linux) ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by horel at Jul 22, 2026, 5:29:30 PM |
Re: Generic European Schuko wall socket – SH3F furniture library Thank you for the detailed feedback. Could you please send one or two screenshots showing the affected surfaces and the viewing angle where they become transparent? If possible, please mark the problematic areas in the screenshot. This would help me identify and fix the flipped normals accurately. A screenshot from both the outside and the inside of the affected surface would be especially helpful. |
| Posted by Keet at Jul 22, 2026, 5:57:02 PM |
Re: Generic European Schuko wall socket – SH3F furniture library![]() Flip the normals of the inner ring and the sides around. The dark slot of the center screw floats above the screw, a single face touching the screw should fix that. I'm not sure if the dark-slots top and bottom should be like that (I can't find an image of that specific real socket) Fixed WallSocket.zip ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by horel at Jul 23, 2026, 3:44:07 AM |
Re: Generic European Schuko wall socket – SH3F furniture library Electrical_EU_wall_socket_v1.1.sh3f CHANGELOG Version 1.1 - Based directly on the published Electrical_EU_wall_socket_v1.0.sh3f package. - Corrected flipped normals on the inner ring. - Corrected flipped normals on the outer side surfaces. - Corrected the floating dark slot of the center screw. - Geometry corrections in WallSocket.mtl and WallSocket.obj files supplied by Keet / Dodecagon. - Removed modelRotation#1 because the corrected OBJ already contains the required orientation. |
| Posted by Keet at Jul 23, 2026, 6:53:32 AM |
Re: Generic European Schuko wall socket – SH3F furniture library About not needing the rotation correction: When you export an object in Sweet Home 3D the object is exported with its position in the 2D design pane. Your initial socket could have been corrected by rotating it in the 2D pane with the correct side to the front before export. You can see the result when you rotate an object 45° and export it. When you import it again it has the same 45° position as when you exported it. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by [email protected] at Jul 23, 2026, 11:06:06 AM |
Re: Generic European Schuko wall socket – SH3F furniture library Good morning Keet, It has been nearly two years since I last paid attention to Sweethome (in my 80s, I’ve kept my mind and coding skills sharp by forcing Excel to do things it wasn't officially designed to do—all without letting it touch the actual output until the very end, when it was ready to be served, whether for Excel or, I imagine, for Sweethome when generating XML), but yesterday I stumbled upon this discussion of yours. I believe that, worldwide, new electrical installations rely on modern standards based on fixed-size, numbered wall boxes—whether flush-mounted or surface-mounted (types 501, 502, 503, 504, 505, 506, 508, with the initial digit—5 or 6—indicating the intended use: flush-mount vs. surface-mount). The final digit indicates the maximum number of electrical modules (inserts) the box can hold. These modules can be single, double, or triple units, but they all share the same maximum depth—dictated by the box itself—regardless of the manufacturer. The box accommodates any mounting plate produced (it is the plate that actually determines the type and number of modules contained). A decorative cover plate—chosen for shape and color to provide the visual finish—is then placed over this assembly. Following this logic in Sweethome, the actual content of the electrical module is simply an image of the real finished product (perhaps with a depth effect) placed upon a standard-sized structure (width and depth) that represents it—albeit with some approximation, as we are dealing with minimal visual dimensions that wouldn't be visible except in an exploded view. This sequence makes the construct independent of the specific finished product; any international module style can be applied to the individual electrical unit. The box will be recessed into the wall (or surface-mounted, in the case of external boxes), and the conduits carrying the system's wiring will be attached to it; only the decorative faceplate—and the functional electrical components—will be visible flush with the wall surface (note that decorative faceplates cannot be used with surface-mounted boxes). This logic could lead to the creation of a construction plugin featuring texture libraries: one for regional formats (UK, US, IT, etc.) representing standard national socket types; one for the various standards of mounting boxes (flush-mount vs. surface-mount); one for the individual module structures (blocks with fixed depth and height but variable width); and one for decorative faceplates (shapes and colors) along with the associated logic (e.g., a box holding a maximum of 3 modules could accommodate one 1-slot and one 2-slot module, or three 1-slot modules, or various combinations—including "blank" filler modules). As I am neither an expert nor a Java programmer, I won't be attempting this myself. IIn my own older SweetHome projects, I used a similar technique (creating my own library) to establish a single-brand standard (BTicino) with combinable layouts. I utilized the ability to toggle the visibility of individual modules on a standard mounting bracket and applied the chosen function texture and faceplate color to them. The result was visually realistic—even when zoomed in—and, by using wall transparency, the setup could be used to map out the actual electrical wiring. I am sharing this simply to inform others and perhaps suggest this possibility to anyone who might be interested. Best Regards. |
| Posted by [email protected] at Jul 23, 2026, 11:18:26 AM |
Re: Generic European Schuko wall socket – SH3F furniture library Sorry, I forgot that by doing this, the objects placed in place can each vary in content. That is, you can add a simple Schuko socket where there was a single socket, or you can add a switch and a multipurpose Schuko socket, or you can swap their positions simply by adjusting the relevant textures. Regardsstumbled upon this discussion of yours. I believe that, worldwide, new electrical installations rely on modern standards based on fixed-size, numbered wall boxes—whether flush-mounted or surface-mounted (types 501, 502, 503, 504, 505, 506, 508, with the initial digit—5 or 6—indicating the intended use: flush-mount vs. surface-mount). The final digit indicates the maximum number of electrical modules (inserts) the box can hold. These modules can be single, double, or triple units, but they all share the same maximum depth—dictated by the box itself—regardless of the manufacturer. The box accommodates any mounting plate produced (it is the plate that actually determines the type and number of modules contained). A decorative cover plate—chosen for shape and color to provide the visual finish—is then placed over this assembly. Following this logic in Sweethome, the actual content of the electrical module is simply an image of the real finished product (perhaps with a depth effect) placed upon a standard-sized structure (width and depth) that represents it—albeit with some approximation, as we are dealing with minimal visual dimensions that wouldn't be visible except in an exploded view. This sequence makes the construct independent of the specific finished product; any international module style can be applied to the individual electrical unit. The box will be recessed into the wall (or surface-mounted, in the case of external boxes), and the conduits carrying the system's wiring will be attached to it; only the decorative faceplate—and the functional electrical components—will be visible flush with the wall surface (note that decorative faceplates cannot be used with surface-mounted boxes). This logic could lead to the creation of a construction plugin featuring texture libraries: one for regional formats (UK, US, IT, etc.) representing standard national socket types; one for the various standards of mounting boxes (flush-mount vs. surface-mount); one for the individual module structures (blocks with fixed depth and height but variable width); and one for decorative faceplates (shapes and colors) along with the associated logic (e.g., a box holding a maximum of 3 modules could accommodate one 1-slot and one 2-slot module, or three 1-slot modules, or various combinations—including "blank" filler modules). As I am neither an expert nor a Java programmer, I won't be attempting this myself. IIn my own older SweetHome projects, I used a similar technique (creating my own library) to establish a single-brand standard (BTicino) with combinable layouts. I utilized the ability to toggle the visibility of individual modules on a standard mounting bracket and applied the chosen function texture and faceplate color to them. The result was visually realistic—even when zoomed in—and, by using wall transparency, the setup could be used to map out the actual electrical wiring. I am sharing this simply to inform others and perhaps suggest this possibility to anyone who might be interested. Best Regards. |
| Posted by [email protected] at Jul 23, 2026, 11:22:03 AM |
Re: Generic European Schuko wall socket – SH3F furniture library in italiano.....che pasticcio di scrittura....chiedo scusa a tutti |
| Posted by [email protected] at Jul 23, 2026, 11:31:39 AM |
Re: Generic European Schuko wall socket – SH3F furniture libraryquesto il vero messaggio, di nuovo scusa a tutti. Sorry, I forgot that by doing this, each of the objects placed in place can vary in content, such as adding a simple Schuko socket where there was a single socket, or adding a switch and a multipurpose Schuko socket, or even swapping their positions simply by changing the relative textures. Furthermore, since they are textures, nothing prevents you from replacing the socket textures with the corresponding electrical symbols, and the decorative plate (which is a subject) could be of a different type, for example, transparent. This, combined with the fact that the physical object of the electrical socket can be made transparent, would result in a box with only the standard electrical symbols. Regards |
| Posted by [email protected] at Jul 23, 2026, 11:54:12 AM |
Re: Generic European Schuko wall socket – SH3F furniture library the real difficulty in my case was to create balanced rectangular textures for the single electric fruits (obtained in the end with the icon resolution)......we are talking about objects that have dimensions of about 1 cm in width and less than 3 in height (the single ones and proportionally the others) |
| Posted by [email protected] at Jul 23, 2026, 12:09:25 PM |
Re: Generic European Schuko wall socket – SH3F furniture library The technique for creating these objects, in my case, is quite complicated at first. Each support must contain multiple independent sub-objects that occupy the same space for all combinations of position and size of the support... for example, a 504 support IN A SINGLE PORTION OF SPACE contains 4 single objects, 3 double and 2 triple to then cover any permitted positioning of the electrical devices in the display but it follows very precise mathematical rules and practical rules as well since the blind electrical devices (those with a flat surface) are only single. |
| Posted by [email protected] at Jul 23, 2026, 12:20:17 PM |
Re: Generic European Schuko wall socket – SH3F furniture library The individual fruits were initially hypothesized with a solid base (in my case a very simple texturized cube deformed ad hoc) and with the application of the relative texture on the single external face but this made the texture flat and without depth. To obtain the effect I had to manipulate the objects creating a vertical edge that, combined with the surface, also incorporated the texture vertically (on the edge)... this thing produced a false three-dimensional (the texture filled the surface starting from the small vertical edge). |
| Posted by [email protected] at Jul 23, 2026, 12:33:01 PM |
Re: Generic European Schuko wall socket – SH3F furniture library To do this quickly, I combined two cubes (the first with single texturized faces, the second with a single texture), staggering them and deleting the faces of the fully texturized one. Then I combined the remainder with the single-textured face in a single layer... the relative texture was now applied to the vertical mini portion together with the horizontal one. Once the object was obtained, I could then modify its dimensions. |
| Posted by [email protected] at Jul 23, 2026, 12:35:24 PM |
Re: Generic European Schuko wall socket – SH3F furniture library But these are things that were done years ago and I'm actually just going by memory, so consider them as such. |
| Posted by [email protected] at Jul 23, 2026, 3:01:16 PM |
Re: Generic European Schuko wall socket – SH3F furniture library I am attaching a file showing how I have used this. In this instance, the structural components—the box partially recessed into the wall and the associated electrical conduits—are placed on a separate level dedicated to the actual MEP systems, while this specific level is reserved for the visible elements mounted against the wall. To overlay the textures, I used objects with one invisible face—a deliberate choice—resulting in an object that effectively lacks depth and is completely invisible when viewed from that side. https://www.mediafire.com/file/pp6fia7ahtms9d...rutti_elettrici.sh3d/file |
Current timezone is GMT Sep 13, 2026, 10:53:24 PM |
