Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: The house file is gone after installing alternative java support |
| Print at Jul 21, 2026, 8:54:02 PM | View all posts in this thread on one page |
| Posted by pedrober at May 10, 2010, 4:28:03 PM |
The house file is gone after installing alternative java support After installing alternative Java support, my sh3d files (the whole house) disappeared. I was unable to find them, even using utilities to recover erased files. Any suggestion? |
| Posted by pedrober at May 10, 2010, 5:22:16 PM |
Re: The house file is gone after installing alternative java support I found a previous copy (not complete) in a temp directory but it's necessary to fix this bug. |
| Posted by Puybaret at May 10, 2010, 8:08:49 PM |
Re: The house file is gone after installing alternative java support I never heard about such a problem. What do you mean by "installing alternative Java support"? On system which do you work? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by pedrober at May 11, 2010, 12:12:59 AM |
Re: The house file is gone after installing alternative java support By "installing alternative Java support" I mean this link: javascript:launchSweetHome3DDirectX() As long as I was unable to run the program from my advanced user account (no problem from the administrative account), I followed the FAQ guidelines. So, I discovered the typical log about fatal error from Java runtime environment and I installed the alternative DirectX support. Now it's possible to run the program from my user account. System information: OS: Windows XP Build 2600 Service Pack 3 CPU:total 2 (2 cores per cpu, 1 threads per core) family 6 model 15 stepping 13, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3 Memory: 4k page, physical 1047788k(612500k free), swap 2522632k(2128356k free) vm_info: Java HotSpot(TM) Client VM (16.0-b13) for windows-x86 JRE (1.6.0_18-b07), built on Dec 17 2009 13:35:55 by "java_re" with MS VC++ 7.1 (VS2003) |
Current timezone is GMT Jul 21, 2026, 8:54:02 PM |
