Print at Oct 9, 2026, 4:34:34 AM View all posts in this thread on one page
Posted by balisage at May 1, 2010, 6:21:26 AM
smile   how to update new version?
hi...i found my problem with how to update my sweethome 3d v1.7 with v2.3. should i uninstall the oldest one and install with new or there's another way? could you please help me with this. thanks guys...
Posted by Puybaret at May 1, 2010, 12:12:11 PM
Re: how to update new version?
If you installed Sweet Home 3D with Windows installer, simply run the installer of the new version. You won't lose your furniture library and preferences because they are stored in user directories.
Posted by gracyhelen at May 10, 2010, 4:12:01 PM
hai how to create the 3d house
Posted by Ablondal at May 27, 2010, 1:26:52 AM
When I run the windows installer for V2.4 (to update from 2.3) I get this error:
"Delete file failed; code 5
Access is denied"
Do I need to uninstall 2.3? and If I do will I keep all my saved files?
Thanks.
Posted by Puybaret at May 27, 2010, 10:33:10 AM
You're not obliged to uninstall the previous version of Sweet Home 3D before updating it. The error you mention probably means that the installation program couldn't delete a file or write over it.
I suggest you to install Sweet Home 3D 2.4 in an other directory to avoid this problem. In all cases, upgrading won't delete your saved files, and the models and the textures you imported in Sweet Home 3D.
Posted by Ablondal at May 28, 2010, 2:43:19 AM
Thanks for the help! Great Program, Thanks to all who worked on it!
