Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Parametric Handrail & Fence Generator |
| Print at Oct 5, 2026, 6:41:50 PM | View all posts in this thread on one page |
| Posted by Xlance at Mar 5, 2026, 1:33:21 PM |
Parametric Handrail & Fence Generator A powerful, Java-based procedural modeling tool designed for architects, 3D artists, and CAD engineers. This application streamlines the creation of complex railing systems, fences, and balustrades by replacing manual modeling with a high-fidelity parametric engine. Whether you need a simple glass partition or a complex curved industrial handrail, this tool generates precise geometry in real-time. 🚀 Key Features Fully Parametric Workflow: Adjust post heights, rail diameters, panel thickness, and sub-post spacing on the fly. Dynamic 3D Preview: Integrated JavaFX viewport allows for real-time inspection of geometry with intuitive orbit, pan, and zoom controls. Curvature Logic: Support for both linear and curved segments with adjustable radii—ideal for spiral staircases or rounded balconies. Advanced Geometry Options: Choose from preset profiles (Rectangular, Elliptical) or load Custom OBJ/TXT shapes for rails and posts. Material Physics: Set transparency and reflectivity ($0-100\%$) to visualize glass, polished steel, or matte wood finishes. 💾 Industry-Standard Exports This generator acts as a bridge between procedural design and production. Export your models to: CAD: DXF (AutoCAD), SVG (Vector layouts). 3D Modeling: OBJ (Wavefront) with MTL support, 3DS (3D Studio). Rendering: POV-Ray (.POV) for high-end ray-traced visualizations. https://sourceforge.net/p/sweethome3d/plug-ins/61/ ---------------------------------------- Windows 64bit | Intel i7 | SH3D 8.0 + Plugins |
| Posted by Daniels118 at Mar 6, 2026, 9:18:05 AM |
Re: Parametric Handrail & Fence Generator Very nice tool! Do you plan to convert it into a plugin? |
| Posted by Xlance at Mar 6, 2026, 12:23:06 PM |
Re: Parametric Handrail & Fence Generator @Daniels118 I'm trying to convert it into a plugin, but it's a bit not easy. Feel free to try. I can surely forward you the source if interested :-) ---------------------------------------- Windows 64bit | Intel i7 | SH3D 8.0 + Plugins |
| Posted by Daniels118 at Mar 6, 2026, 3:36:44 PM |
Re: Parametric Handrail & Fence Generator Thank you, but I will be out of the scene for a while. There is no hurry, but if you want to try you may look at how the roof generator works, it's a very good example to see how to transfer a model generated using a general purpose algorithm into sh3d. |
| Posted by Xlance at Mar 17, 2026, 4:52:29 PM |
Re: Parametric Handrail & Fence Generator The Handrail generator plugin is now runnable from inside the new Advanced Shape generator. files posted on Sourceforge https://sourceforge.net/p/sweethome3d/plug-ins/63/ ---------------------------------------- Windows 64bit | Intel i7 | SH3D 8.0 + Plugins |
| Posted by crackwood01 at Mar 28, 2026, 6:03:37 PM |
Re: Parametric Handrail & Fence Generator Can you explain how to make it work with the AdvancedShape generator plugin, i've downloaded all the files, i put them all in the plugins folder, but can't make it work |
| Posted by Xlance at Mar 29, 2026, 12:50:17 PM |
Re: Parametric Handrail & Fence Generator @crackwood01 > Run Sweethome3D > Go to Tools menu > Click Generate 3D Shape > it opens a dialog > Click Advanced Models button > it opens AdvancedShape generator > You will see Generate Handrail and Generate Extrude ---------------------------------------- Windows 64bit | Intel i7 | SH3D 8.0 + Plugins |
Current timezone is GMT Oct 5, 2026, 6:41:50 PM |
