Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: ESC key issue |
| Print at Sep 28, 2026, 8:17:45 AM | |
| Posted by mikimichele82 at Jan 29, 2026, 11:46:09 PM |
ESC key issue Good morning, I have just installed the plugin and run some tests. The lines are drawn correctly on the 3D view, but if I press the ESC key while the plugin is active, I can no longer draw any dimensions and I can’t go back. Is this a known bug, or is there a way to restore the creation of the dimension lines? Thanks in advance Michele |
| Posted by Keet at Jan 31, 2026, 12:09:03 PM |
Re: ESC key issue It might help if you mentioned which plugin. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by mikimichele82 at Jan 31, 2026, 7:20:00 PM |
Re: ESC key issue Yes, you are right! I due a mistake: it was my first time in the forum and Ia pressed “New Thread” instead of “Reply” in a previous conversation. Anyway thanks for your reply and the plugin I refers to is “3D dimensional lines”. Thanks Michele |
| Posted by Daniels118 at Feb 1, 2026, 7:38:23 AM |
Re: ESC key issue Quoting myself: I know there are bugs using the plugin with the latest versions of SweetHome3D. I haven't had the time to fix them, so the only chance is to use the native dimension lines, or downgrade SweetHome3D to a previous version (7.0 should work fine). Keep in mind that native dimension lines can be placed vertically using the edit dialog. |
Current timezone is GMT Sep 28, 2026, 8:17:45 AM |
