Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Moulding Boolean Convert plugin (MBC) |
| Print at Sep 13, 2026, 7:50:33 PM |
| Posted by dorin at Jan 19, 2026, 7:22:33 PM |
Re: Moulding Boolean Convert plugin (MBC) Merci! From what I've seen, you've grasped the essentials. Otherwise, the sky's the limit (or the limits of the computer). Unfortunately, it's addictive (at least for me) and distracts me from the main goal: to make it work and make it good. But if you are happy, I'm happy too. That's is. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by VeroniQ at Jan 20, 2026, 3:48:14 PM |
Re: Moulding Boolean Convert plugin (MBC) Pouvoir se passer de Blender ou Art of illusion (qui sont des logiciels quand même sacrément compliqués) pour ce type d'opération est un grand pas. Merci Dorin !! |
| Posted by snmavronis at Jan 21, 2026, 11:02:17 PM |
Re: Moulding Boolean Convert plugin (MBC) Looks very interesting! I've installed the plugin. I may try this for some bedroom furniture I want to make with recessed panels and outer wood trim. The trim is rounded itself though. As far as the bevel feature goes it looks like only a flat angled bevel. Will the bevel work with shapes made with curved walls? Maybe in the future there can be other bevel shape options but not sure that's possible like a convex and concave curved bevel choices too... ---------------------------------------- Steve N Mavronis - Retired PC Tech |
| Posted by Keet at Jan 22, 2026, 2:06:47 PM |
Re: Moulding Boolean Convert plugin (MBC) Maybe in the future there can be other bevel shape options but not sure that's possible like a convex and concave curved bevel choices too... Take a look at my DodecagonShapes library. I have added rounded bevel shapes for an inset bevel. The shapes for an outside rounded bevel have been part of the library for a long time.You could have created similar shapes with the new MBC plugin but it would require several steps to get to the inset corner. And of course the shapes in the library are optimized to only have those faces that are visible. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by snmavronis at Jan 22, 2026, 3:57:15 PM |
Re: Moulding Boolean Convert plugin (MBC) Thanks cool Keet and may come in handy down the road. I have to make custom curved inserts as molds for trims to make scale models of an 80's bedroom set we have. For now they will probably have right angles and textures will help fake the curves with edge shadows in the textures I'll apply. ---------------------------------------- Steve N Mavronis - Retired PC Tech |
| Posted by Xlance at Mar 1, 2026, 5:12:41 AM |
Re: Moulding Boolean Convert plugin (MBC) Boolean operations would work nicely with the 3D objects generator plugin I'm workong on :-) ---------------------------------------- Windows 64bit | Intel i7 | 8GB Ram | SH3D 7.5 + Plugins |
| Posted by Keet at Mar 3, 2026, 12:01:00 PM |
Re: Moulding Boolean Convert plugin (MBC) Boolean operations would work nicely with the 3D objects generator plugin I'm workong on :-) Tell us more! I've been thinking about such a plugin but I simply can't find the time without giving up on 'normal' Sweet Home 3D work.---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Xlance at Mar 5, 2026, 1:31:00 PM |
Re: Moulding Boolean Convert plugin (MBC) Part I is posted at: https://sourceforge.net/p/sweethome3d/plug-ins/61/ ---------------------------------------- Windows 64bit | Intel i7 | 8GB Ram | SH3D 7.5 + Plugins |
Current timezone is GMT Sep 13, 2026, 7:50:33 PM |
