Print at Aug 22, 2026, 10:01:56 AM
Posts: 24   Pages: 3   [ 1 2 3 | Next Page ]
Posted by MrMarkie at Apr 15, 2010, 3:25:59 PM
How to import furniture in Applet
Hi I'm playing around with Sweet Home 3D and have managed to serve it as an applet from a webserver. Only problem is I have no furniture in the applet, how and where do I put which files to remedy this?
Best Regards
Markus Larsson
Posted by Puybaret at Apr 18, 2010, 1:56:46 PM
Re: How to import furniture in Applet
Short answer: read the information about parameters named furnitureCatalogURLs and texturesCatalogURLs in SweetHome3DApplet javadoc.
If you look at the source code of the Online version hosted on sweethome3d.eu, you'll see these two parameters are the files furnitureCatalog.zip, additionalFurnitureCatalog.zip and texturesCatalog.zip.
The PluginFurnitureCatalog.properties and PluginTexturesCatalog.properties contained in these zip files reference all the icon and 3D model files hosted on this server.
You can edit them and replace the code base http://www.sweethome3d.eu/ by the one of your server and copy all the 3D model and icon files you want on your server.
Important note: in no case, I give you (or other people reading this thread) the authorization to host unmodified versions of the files furnitureCatalog.zip, additionalFurnitureCatalog.zip and texturesCatalog.zip on your server. You must reference 3D model and icon files hosted on your server, and not files on sweethome3d.eu server.
Don't host the files furnitureCatalog.zip, additionalFurnitureCatalog.zip and texturesCatalog.zip on your server if you don't understand the exact meaning of the required changes.
[01/18/2011 - Update from developer : In version 2.4, the two furnitureResourcesURLBase and texturesResourcesURLBase parameters were added to SweetHome3DApplet class to simplify catalogs deployment.
Thus, the furnitureCatalog.zip, additionalFurnitureCatalog.zip and texturesCatalog.zip hosted on this server don't contain absolute URLs anymore but URLs relative to the furnitureResourcesURLBase and texturesResourcesURLBase parameters I added to the applet of the Online version.
Feel free to use these files unmodified now, as long as you take care to change the URL base to avoid using models hosted on sweethome3d.com server in your applet.
Posted by MrMarkie at Apr 19, 2010, 9:16:07 AM
I see, thank you for the quick response. I will make those changes and make sure all things point where they should point.
Thanks again for the response and for this very useful application.
Sincerly
Markus Larsson
Posted by bellskar at Apr 29, 2010, 6:52:37 PM
I just did following but Applet is still loading without any feature.
Added the following parameters in SweetHome3DApplet.html
var parameters = {java_arguments:"-Xmx512m -Dcom.eteks.sweethome3d.deploymentInformation=Online",
showMemoryStatus:"true",
userLanguage:"en",
furnitureCatalogURLs:"/online/furnitureCatalog.zip /online/additionalFurnitureCatalog.zip",
texturesCatalogURLs:"/online/texturesCatalog.zip",
listHomesURL:"",
readHomeURL:"",
writeHomeURL:""
- I downloaded the same Catalogs from in zip archives you linked above.
- Then uncompressed these zip files to modify the reference URLS to my own server and then again zipped in the same way.
- I downloaded one or two models from the sweethome3d.eu as were linked in the *catalog.properties and placed on my own server with the same directory structure. I selected only one or two items/models to test the working.
the final *.properties files were as below. I am not disclosing the actual URL considering the privacy. but I tested the urls after placing the models if they work on direct access or not. and they are actually working.
furnitureCatalog.zip!\PluginFurnitureCatalog.properties
name#1=Bed 140x190
category#1=Bedroom
icon#1=http://my_url/models/bed140x190.png
model#1=jar:http://my_url/models/bed140x190.zip!/bed140x190.obj
width#1=158
depth#1=208
height#1=70
movable#1=true
doorOrWindow#1=false
name#2=Chest
category#2=Bedroom
icon#2=http://my_url/models/chest.png
model#2=jar:http://my_url/models/chest.zip!/chest.obj
width#2=100
depth#2=55
height#2=80
movable#2=true
doorOrWindow#2=false
name#3=Bedside table
category#3=Bedroom
icon#3=http://my_url/models/bedsideTable.png
model#3=jar:http://my_url/models/bedsideTable.zip!/bedsideTable.obj
width#3=38
depth#3=38
height#3=50
movable#3=true
doorOrWindow#3=false
texturesCatalog.zip!\PluginTexturesCatalog.properties
name#1=Wooden floor
category#1=Floor
image#1=http://my_url/textures/woodenFloor.jpg
width#1=42.5
height#1=42.5
additionalFurnitureCatalog.zip!\PluginFurnitureCatalog.properties
name#1=Triple window
category#1=Doors and windows
icon#1=http://my_url/models/contributions/DianaWindow.png
model#1=jar:http://my_url/models/contributions/DianaWindow.zip!/DianaWindow.obj
width#1=389.6
depth#1=25.6
height#1=210.0
movable#1=false
doorOrWindow#1=true
creator#1=Artist373
lastly, is there any way to download all the models from sweethome3d.eu in an archive rather than downloading them each individually. Ofcourse if it's authorised by sweethome3d.eu.
thanks
Posted by Puybaret at Apr 29, 2010, 9:08:31 PM
The first thing I would do is to simply import the ZIP files you created in the offline version of Sweet Home 3D after changing their extension from zip to sh3f, and check if the models listed in them appear in Sweet Home 3D catalog.
If this succeeds, you should check if http://my_url/online/furnitureCatalog.zip is accessible. As you kept a slash in front of "/online/furnitureCatalog.zip", online directory should be at root. If you remove the first slash from "/online/furnitureCatalog.zip", online will be relative to applet "codebase" attribute.
The two things that forbids me to do this is time and bandwidth.
Time is a concern since I would have to update this archive each time I add models in additionalFurnitureCatalog.zip, and this would be one more task I shouldn't forget.
Bandwidth is my main concern since this archive weights 32 MB at this time, and I'm always frightened by the idea of hosting such a big file (Sweet Home 3D installers are big files too but they are hosted on SourceForge.net servers).
If you feel comfortable with regular expressions, you can transform the lines containing ".zip" and ".png" in PluginFurnitureCatalog.properties into wget commands, taking care of subdirectories.
If not, the only solution I see at this time is to create that file on demand and publish it temporarily.
If you don't have a better idea, send me a private message or an email.
Posted by bellskar at Apr 30, 2010, 3:19:01 PM
Great!!! it was the slash. I actually was using a specific folder named SH3D as the application on the root. but didn't remove the "/". after your post I just got that and removed the "/" before "online" to use it as relative to "codebase" which in my case was "http://my_url/SH3D/"
I got that. it's understandable.
Won't it be the other part from downloading the catalogs from sweethome3d server. the hell is actually to download each zip file :P
any ways. the use of regular expressions in "*.properties" is also a good for me but ofcourse I would have to download the zip files separately each.
I'll contact you via email. That would be great and so kind of you.
Thanks a lot.
Posted by Carina2011 at May 25, 2012, 10:16:01 AM
Hello, i have make this like your description, but my furniture shows not in the sweethome3d when it starts.
urls like this http://my_url/online/furnitureCatalog.zip works and found my zip
i have also tested this with a backslah / or not or with the relativ url.
must i make other changes in another class of sweethome 3d ?
Posted by Puybaret at May 25, 2012, 10:51:41 AM
Could you paste here the properties of one of your object, as well as the params you used in your applet?
Posted by ndhduong at Jun 20, 2012, 11:42:06 AM
I use source v3.5 downloaded from here (3.5 src )
I tried to run the code locally as an applet within Eclipse, and v3.5 source is a little different from what is explained in this post:
1.There is no zip files for catalog or texture. All the models and textures are individual files in io/resources folder. The .properties files are located in io folder
2.Parameters has to be set in Run Configurations option of Eclipse
So I followed the instructions and did the following:
1.Change path for models and textures in .properties files, as
icon#1=./resources/bed140x190.png
model#1=./resources/bed140x190.obj
2.Set parameters as followed:
Value:"./io/"
Value:"./io/"
However, the applet run without any models on the top left section.
I have intentionally changed the path for models to a wrong one then Eclipse produced error of "Unknown resource", which means the paths I used above should be processed properly.
About the parameters, I have tried both relative and absolute path (C:/...) but none worked.
Please give me some inputs.
Thank you
Posted by Puybaret at Jun 20, 2012, 6:10:13 PM
The program doesn't handle paths but URLs. I hoped that the URL suffix in the parameter names would be enough to suggest it. sad
