Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Linux: Can't import furniture |
| Print at Sep 10, 2026, 10:33:23 PM | View all posts in this thread on one page |
| Posted by karladidas at Apr 13, 2010, 5:45:03 PM |
Linux: Can't import furniture Hi, I am using Sweet Home 3D v2.3 on Ubuntu 9.10, Java 1.6.0_18. When I press "Import Furniture" nothing happens. If I copy a model to the .etek/sweethome3d/furniture directory it doesn't show in the program. If I try to "Import furniture library" I get a file browser but again can't import any models. Could some one please help? Thanks K |
| Posted by karladidas at Apr 13, 2010, 6:20:16 PM |
Re: Linux: Can't import furniture Just managed to get an error dump: Exception in thread "AWT-EventQueue-0" java.lang.RuntimeException: java.lang.reflect.InvocationTargetException at com.eteks.sweethome3d.swing.ControllerAction.actionPerformed(Unknown Source) at com.eteks.sweethome3d.swing.ResourceAction$AbstractDecoratedAction.actionPerformed(Unknown Source) at javax.swing.AbstractButton.fireActionPerformed(Unknown Source) at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source) at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source) at javax.swing.DefaultButtonModel.setPressed(Unknown Source) at javax.swing.AbstractButton.doClick(Unknown Source) at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source) at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source) at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source) at java.awt.Component.processMouseEvent(Unknown Source) at javax.swing.JComponent.processMouseEvent(Unknown Source) at java.awt.Component.processEvent(Unknown Source) at java.awt.Container.processEvent(Unknown Source) at java.awt.Component.dispatchEventImpl(Unknown Source) at java.awt.Container.dispatchEventImpl(Unknown Source) at java.awt.Component.dispatchEvent(Unknown Source) at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source) at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source) at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source) at java.awt.Container.dispatchEventImpl(Unknown Source) at java.awt.Window.dispatchEventImpl(Unknown Source) at java.awt.Component.dispatchEvent(Unknown Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.run(Unknown Source) Caused by: java.lang.reflect.InvocationTargetException at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) ... 30 more Caused by: java.lang.IllegalArgumentException: adding a container to a container on a different GraphicsDevice at java.awt.Component.checkGD(Unknown Source) at java.awt.Container.checkGD(Unknown Source) at java.awt.Container.checkGD(Unknown Source) at java.awt.Container.checkGD(Unknown Source) at java.awt.Container.checkGD(Unknown Source) at java.awt.Container.checkGD(Unknown Source) at java.awt.Container.checkGD(Unknown Source) at java.awt.Container.checkGD(Unknown Source) at java.awt.Container.checkGD(Unknown Source) at java.awt.Container.addImpl(Unknown Source) at java.awt.Container.add(Unknown Source) at javax.swing.JOptionPane.initDialog(Unknown Source) at javax.swing.JOptionPane.createDialog(Unknown Source) at javax.swing.JOptionPane.createDialog(Unknown Source) at com.eteks.sweethome3d.swing.WizardPane.displayView(Unknown Source) at com.eteks.sweethome3d.viewcontroller.WizardController.displayView(Unknown Source) at com.eteks.sweethome3d.viewcontroller.FurnitureCatalogController.importFurniture(Unknown Source) at com.eteks.sweethome3d.viewcontroller.HomeController.importFurniture(Unknown Source) ... 34 more I hope that helps? |
| Posted by Puybaret at Apr 13, 2010, 7:19:59 PM |
Re: Linux: Can't import furniture This stack trace looks like Brill's one when he tried to detach the 3D view on his computer. Wouldn't you have two screens? If yes, could you check if it still fails when you use Sweet Home 3D on the main screen? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by karladidas at Apr 14, 2010, 6:15:17 PM |
Re: Linux: Can't import furniture Puybaret, Yes I do have 2 screens and was using Sweet Home 3D on my 2nd monitor. I just had a quick try using the main screen and can confirm that the import furniture dialog appears and models can be imported. Thanks for the help! |
Current timezone is GMT Sep 10, 2026, 10:33:24 PM |
