Print at Sep 22, 2026, 3:04:16 PM View all posts in this thread on one page
Posted by surfer63 at Nov 17, 2025, 5:23:49 PM
Opening a .sh3d file in Sweethome3D, minimized Sweethome3D
I am using SweetHome3D on an 8GB i5-1245U chromebook with linux (Crostini) enabled. The version 7.5 linux SweetHome3D package works fine as such. I also created a .desktop file for it to make a menu item.
When I open SweetHome3D, it opens normally and everything is fine.
When I open a .sh3d file from SweetHome3D, or double-click a .sh3d file, it is opened, but SweetHome3D is completely minimized. There is a few pixels wide application bar in the center of the screen. When I drag on the left side, I can extend the application bar to the left.
When extended to the left, I can click the maximize menubar icon.
I also used the (unofficial) "X-GNOME-Window-Maximized=true" in the .desktop file, but that one is not recognized.
Note that ChromeOS is Wayland with an X-compatibility layer for X-apps.
I already tried adding
sleep 1
wmctrl -r "SweetHome3D" -b add,maximized_vert,maximized_horz
wmctrl -a "SweetHome3D"
to the SweetHome3D script
or add
-Dsun.awt.noerasebackground=true
or add
-Djdk.gtk.version=2
to the "java ... -jar" command line
Does anyone have an idea?
Posted by Keet at Nov 18, 2025, 5:35:47 PM
Re: Opening a .sh3d file in Sweethome3D, minimized Sweethome3D
It's most likely related to Wayland. The very few problems on Linux are often because of Wayland. Any way you can change to GDM?
