Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Launch failure: sunflow-0.07.3b.jar |
| Print at Sep 10, 2026, 9:34:03 PM | |
| Posted by SW3DFnx at Apr 4, 2010, 9:49:16 AM |
Launch failure: sunflow-0.07.3b.jar Bonjour, Since end of march 2010, I managed to run SH3D-2.3 once. I have used SH3D from time to time before without problem. Since then, I get a failure message after the launch starting with with the following error: java.io.FileNotFoundException: http://www.sweethome3d.eu/lib/sunflow-0.07.3b.jarAny advice to correct this problem ? --- OS: linux Ubuntu 8.04.4 LTS (Hardy) |
| Posted by Puybaret at Apr 5, 2010, 9:52:33 AM |
Re: Launch failure: sunflow-0.07.3b.jar Sorry, I didn't understand whether Sweet Home 3D runs or not on your computer, once the message you mention appears. For your information, sunflow-0.07.3b.jar library doesn't exist anymore and was replaced by sunflow-0.07.3c.jar in Sweet Home 3D 2.3. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by SW3DFnx at Apr 5, 2010, 11:35:32 PM |
Re: Launch failure: sunflow-0.07.3b.jar SH3D-2.2 was starting and ran on my computer Now, the program is starting, but is not running anymore: I get the welcome display (SweetHome 3D, eteks), and then two windows: FYI, I'm lauching the application with the following command: /usr/bin/javaws $HOME/SweetHome3D/SweetHome3D.jnlp |
| Posted by hansmex at Apr 6, 2010, 1:05:13 AM |
Re: Launch failure: sunflow-0.07.3b.jar Why don't you just double-click the program icon? ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by SW3DFnx at Apr 6, 2010, 2:01:29 AM |
Re: Launch failure: sunflow-0.07.3b.jar To hansmex: The double click calls the same command and causes the exact same behaviour. I have also tried to reinstall SH3D by clicking on the banner "Lauch SH3D with Java Web Start" on page http://www.sweethome3d.eu/download.jsp but it only brings me the Java official download page. By the way, the version of javaws installed on my computer is "Java(TM) Web Start 1.6.0_17" |
| Posted by hansmex at Apr 6, 2010, 4:02:30 AM |
Re: Launch failure: sunflow-0.07.3b.jar SW3DFnx: Why don't you try an upgrade to Lucid 10.04? It's still a beta, but very stable. When using Ubuntu 8.04 I had problems with outdated video drivers, that were solved after upgrading to 09.10. However, 9.10 wasn't very stable, so I decided to upgrade to 10.04 which you can find here . SH3D works fine on my computer. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Puybaret at Apr 7, 2010, 3:26:16 PM |
Re: Launch failure: sunflow-0.07.3b.jar "Erreur d'application: impossible de lancer l'application" Please, click on the Details button, and copy paste here the information shown in the Exception tab (onglet). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by SW3DFnx at Apr 7, 2010, 11:42:41 PM |
Re: Launch failure: sunflow-0.07.3b.jar Here is the content of "Exception" tab: java.io.FileNotFoundException: http://www.sweethome3d.eu/lib/sunflow-0.07.3b.jar |
| Posted by Puybaret at Apr 8, 2010, 9:20:12 AM |
Re: Launch failure: sunflow-0.07.3b.jar Referencing a local file to run javaws doesn't seem to be a good choice, when the remote file changed. You should run Sweet Home 3D with the command: /usr/bin/javaws http://www.sweethome3d.eu/SweetHome3D.jnlpor replace $HOME/SweetHome3D/SweetHome3D.jnlp by its new version available at http://www.sweethome3d.eu/SweetHome3D.jnlp. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by SW3DFnx at Apr 9, 2010, 4:24:04 AM |
Re: Launch failure: sunflow-0.07.3b.jar Merci ! the command: /usr/bin/javaws http://www.sweethome3d.eu/SweetHome3D.jnlpworks very well. Is this a relaible method that can be recommended for all linux users when the link "Lauch SH3D with Java Web Start" on page http://www.sweethome3d.eu/download.jsp doesn't work ? For Online usage: /usr/bin/javaws http://www.sweethome3d.eu/SweetHome3D.jnlpFor Offline usage: In a chosen directory, download firstly the SH3D launch file with (for instance): And launch SH3D with the command /usr/bin/javaws ./SweetHome3D.jnlp |
| Posted by hansmex at Apr 9, 2010, 10:48:15 AM |
Re: Launch failure: sunflow-0.07.3b.jar SW3DFnx: I'm using Ubuntu 11.04. I prefer to use the downloaded JNLP file because it automatically puts an icon on the desktop. After changing the permissions for the icon execution, I get a nice SH3D icon that launches the program after double-clicking. This works whether I'm online or offline. (I had to disconnect to test this, because I'm online 24/7) The command "under" the icon is javaws "/home/hans/.netx/cache/http/www.sweethome3d.eu/SweetHome3D.jnlp" . Although it's different than your command, it's what SH3D (and Ubuntu?) automatically create. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by SW3DFnx at Apr 10, 2010, 12:05:59 AM |
Re: Launch failure: sunflow-0.07.3b.jar hansmex: Which command or action have you used to download the jnlp file ? Does the directory where you store it matter ? FYI, in my configuration, I don't have a "$HOME/.netx/" directory. |
| Posted by hansmex at Apr 10, 2010, 8:43:12 AM |
Re: Launch failure: sunflow-0.07.3b.jar SW: I used the link from the post above [Apr 8, 2010 8:20:12 AM]. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 10, 2026, 9:34:03 PM |
