Print at Sep 24, 2026, 1:43:12 AM View all posts in this thread on one page
Posted by pau at Apr 3, 2010, 7:27:52 PM
Crash after Java update
Hello everyone.
I installed SweetHome3d 2.3 a few days ago. Everything was just fine. After Java software update program started to crash with no errors, warnings, exceptions etc. in the following situation:
- start the program;
- hide 3d view panel by clicking on the arrow on separator (program could crash, but not every time);
- then hide the furniture panel by clicking on the arrow on separator - program crashes every time.
I updated graphic drivers to the latest version, but it did not solve the problem.
Here is my system description:
- Windows Vista 32;
- ATI Radeon HD 2400 PRO (8.712.0.0 2010-03-02);
- Java 1.6 update 19 (build 1.6.0_19-b04).
Can anyone help me to solve the problem?
Thank you very much in advance.
Posted by Puybaret at Apr 4, 2010, 12:14:52 AM
Re: Crash after Java update
You may have the same problem as the one described in this bug. sad
Could you hide the navigation arrows with preferences and confirm whether it still crashes or not?
Posted by pau at Apr 4, 2010, 8:13:45 AM
First, thank you for reply.
I hide 3d navigation arrows (Preferences dialog) and after that hiding 3d panel and furniture panel goes without any problems. When I select to show the 3d navigation arrows, program crashes again. So, I can solve the problem that way, but I think this is a kind of a bug :(
And one more thing - when I start the program dialog box appears, saying that "Program requested to go online. Ok | Cancel" If I select "Cancel" program will not start. I did not get that message before. What if I do not have an Internet connection?
I know that the question is not about 3d stuff, but still ...
Posted by pau at Apr 4, 2010, 12:28:16 PM
I have the same problem on Fedora 12. The solution is the same - hide 3d navigation arrows via preferences dialog.
Posted by Puybaret at Apr 12, 2010, 5:52:00 PM
Could you post the Java crash report you got (it's a file named hs_err_pid####.log)?
This should help Java 3D team to fix this bug.
Posted by pau at Apr 12, 2010, 7:01:21 PM
of course I could, but I do not know where to find it :) so, if you tell me where to find the crash report I will send it ... and I do not know where to send it :) so, tell me please where I can find the crash report and where I can send it to. I think I can do it then :)
Posted by hansmex at Apr 12, 2010, 7:11:01 PM
Pau:
Every operating system has a SEARCH function that you can use to fin files on your hard disk. It's just an idea.
Posted by Puybaret at Apr 12, 2010, 7:47:14 PM
The crash report is a text file. Simply copy paste its content in a message of this thread.
Thank you for your help.
Posted by pau at Apr 15, 2010, 8:01:54 AM
Here is a crash report (C:\Windows\System32\hs_err_pid2352.log):
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x08664dcd, pid=2352, tid=508
# JRE version: 6.0_19-b04
# Java VM: Java HotSpot(TM) Client VM (16.2-b04 mixed mode, sharing windows-x86 )
# Problematic frame:
# C [extension105815763305391408.dll+0x4dcd]
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x06c95800): JavaThread "J3D-Renderer-1" [_thread_in_native, id=508, stack(0x07ff0000,0x08040000)]
siginfo: ExceptionCode=0xc0000005, reading address 0xfffffffc
Registers:
EAX=0xffffffff, EBX=0x00000000, ECX=0xffffffff, EDX=0x00000000
ESP=0x0803f7a0, EBP=0x00000000, ESI=0x049159e0, EDI=0x08b79578
EIP=0x08664dcd, EFLAGS=0x00210246
Top of Stack: (sp=0x0803f7a0)
0x0803f7a0: 06c95800 34278d60 0803f854 34278d60
0x0803f7b0: 00000001 00000011 0803f860 0803f828
0x0803f7c0: 0803f854 01f72603 01f78269 34278d60
0x0803f7d0: 0803f8a4 0803f7dc 01f725d7 01f79f47
0x0803f7e0: 06c95910 0803f8a4 08b79578 00000000
0x0803f7f0: 00000000 00000000 0000003c 00000000
0x0803f800: 0000003c 00000001 00000400 00000001
0x0803f810: 00000290 00000004 ffffffff 0803f86c
Instructions: (pc=0x08664dcd)
0x08664dbd: 51 e8 2d eb ff ff 8b 97 b0 02 00 00 8b 44 24 78
0x08664dcd: 8b 04 82 85 c0 89 44 24 7c 75 24 a1 b4 3c 71 08
Stack: [0x07ff0000,0x08040000], sp=0x0803f7a0, free space=13d0803f2d4k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
[error occurred during error reporting (printing native stack), id 0xc0000005]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j javax.media.j3d.NativePipeline.texturemapping(JIIIIIIIIIII[BII)V+0
j javax.media.j3d.NativePipeline.texturemapping(Ljavax/media/j3d/Context;IIIIIIIIIII[BII)V+32
j javax.media.j3d.Canvas3D.texturemapping(Ljavax/media/j3d/Context;IIIIIIIIIII[BII)V+30
j javax.media.j3d.J3DGraphics2DImpl.copyDataToCanvas(IIIIIIII)V+188
j javax.media.j3d.J3DGraphics2DImpl.doFlush()V+227
j javax.media.j3d.J3DGraphics2DImpl.flush(Z)V+52
j com.eteks.sweethome3d.swing.HomeComponent3D$1.canvas3DPostRendered(Ljavax/media/j3d/Canvas3D;)V+31
j com.eteks.sweethome3d.j3d.Component3DManager$1.postRender()V+12
j javax.media.j3d.Renderer.doWork(J)V+6111
j javax.media.j3d.J3dThread.run()V+19
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x091e6000 JavaThread "TimerQueue" daemon [_thread_blocked, id=4080, stack(0x0ac30000,0x0ac80000)]
0x091e5c00 JavaThread "J3D-InputDeviceScheduler-1" [_thread_blocked, id=3592, stack(0x09f60000,0x09fb0000)]
0x091e5400 JavaThread "J3D-SoundSchedulerUpdateThread-1" [_thread_blocked, id=3896, stack(0x09c10000,0x09c60000)]
0x06c99c00 JavaThread "J3D-RenderStructureUpdateThread-1" [_thread_blocked, id=3972, stack(0x09bc0000,0x09c10000)]
0x06c99400 JavaThread "J3D-BehaviorScheduler-1" [_thread_blocked, id=3924, stack(0x09b70000,0x09bc0000)]
0x06c99000 JavaThread "J3D-TransformStructureUpdateThread-1" [_thread_blocked, id=4076, stack(0x09b20000,0x09b70000)]
0x06c98800 JavaThread "J3D-RenderingEnvironmentStructureUpdateThread-1" [_thread_blocked, id=3176, stack(0x09ad0000,0x09b20000)]
0x06c98000 JavaThread "J3D-SoundStructureUpdateThread-1" [_thread_blocked, id=4040, stack(0x09a80000,0x09ad0000)]
0x06c97c00 JavaThread "J3D-GeometryStructureUpdateThread-1" [_thread_blocked, id=3000, stack(0x08c20000,0x08c70000)]
0x06c97400 JavaThread "J3D-BehaviorStructureUpdateThread-1" [_thread_blocked, id=4032, stack(0x08bd0000,0x08c20000)]
0x06c96800 JavaThread "AWT-EventQueue-1" [_thread_blocked, id=2972, stack(0x08af0000,0x08b40000)]
0x06c96400 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=492, stack(0x08aa0000,0x08af0000)]
0x06c95c00 JavaThread "AWT-Shutdown" [_thread_blocked, id=484, stack(0x08a50000,0x08aa0000)]
=>0x06c95800 JavaThread "J3D-Renderer-1" [_thread_in_native, id=508, stack(0x07ff0000,0x08040000)]
0x06c95000 JavaThread "J3D-MasterControl-1" [_thread_blocked, id=3948, stack(0x07f00000,0x07f50000)]
0x06c94c00 JavaThread "J3D-NotificationThread" [_thread_blocked, id=3244, stack(0x071e0000,0x07230000)]
0x06c93800 JavaThread "J3D-TimerThread" [_thread_blocked, id=2996, stack(0x07140000,0x07190000)]
0x06c94000 JavaThread "J3D-RenderingAttributesStructureUpdateThread" [_thread_blocked, id=500, stack(0x06d60000,0x06db0000)]
0x06c94400 JavaThread "Thread-10" [_thread_in_native, id=268, stack(0x06e00000,0x06e50000)]
0x06c92c00 JavaThread "Keep-Alive-Timer" daemon [_thread_blocked, id=3976, stack(0x07e60000,0x07eb0000)]
0x06c92800 JavaThread "TimerQueue" daemon [_thread_blocked, id=176, stack(0x07780000,0x077d0000)]
0x06c92000 JavaThread "D3D Screen Updater" daemon [_thread_blocked, id=3936, stack(0x07330000,0x07380000)]
0x01e3c800 JavaThread "CacheCleanUpThread" daemon [_thread_blocked, id=1496, stack(0x070a0000,0x070f0000)]
0x01e3c000 JavaThread "CacheMemoryCleanUpThread" daemon [_thread_blocked, id=2880, stack(0x07050000,0x070a0000)]
0x01d0b400 JavaThread "DestroyJavaVM" [_thread_blocked, id=2356, stack(0x007b0000,0x00800000)]
0x01e3a000 JavaThread "Javaws Secure Thread" daemon [_thread_blocked, id=3828, stack(0x06db0000,0x06e00000)]
0x01e39800 JavaThread "AWT-Windows" daemon [_thread_in_native, id=2296, stack(0x01c00000,0x01d00000)]
0x01e38800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=2456, stack(0x06a90000,0x06ae0000)]
0x01dfa400 JavaThread "traceMsgQueueThread" daemon [_thread_blocked, id=3156, stack(0x069f0000,0x06a40000)]
0x01dd1c00 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=2400, stack(0x05e40000,0x05e90000)]
0x01dce400 JavaThread "CompilerThread0" daemon [_thread_blocked, id=2192, stack(0x05df0000,0x05e40000)]
0x01dcd400 JavaThread "Attach Listener" daemon [_thread_blocked, id=2712, stack(0x05da0000,0x05df0000)]
0x01dca400 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=2204, stack(0x05d50000,0x05da0000)]
0x01d84c00 JavaThread "Finalizer" daemon [_thread_blocked, id=2220, stack(0x043e0000,0x04430000)]
0x01d83800 JavaThread "Reference Handler" daemon [_thread_blocked, id=2268, stack(0x042d0000,0x04320000)]
Other Threads:
0x01d82000 VMThread [stack: 0x01f10000,0x01f60000] [id=1484]
0x01dd7000 WatcherThread [stack: 0x05f30000,0x05f80000] [id=2284]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 5056K, used 3072K [0x13f00000, 0x14470000, 0x1e9a0000)
eden space 4544K, 58% used [0x13f00000, 0x14193718, 0x14370000)
from space 512K, 84% used [0x143f0000, 0x1445c970, 0x14470000)
to space 512K, 0% used [0x14370000, 0x14370000, 0x143f0000)
tenured generation total 10944K, used 5393K [0x1e9a0000, 0x1f450000, 0x33f00000)
the space 10944K, 49% used [0x1e9a0000, 0x1eee45f8, 0x1eee4600, 0x1f450000)
compacting perm gen total 12288K, used 9470K [0x33f00000, 0x34b00000, 0x37f00000)
the space 12288K, 77% used [0x33f00000, 0x3483fad8, 0x3483fc00, 0x34b00000)
ro space 10240K, 51% used [0x37f00000, 0x3842ae00, 0x3842ae00, 0x38900000)
rw space 12288K, 54% used [0x38900000, 0x38f972d8, 0x38f97400, 0x39500000)
Dynamic libraries:
0x00400000 - 0x00424000 C:\Program Files\Java\jre6\bin\javaw.exe
0x77d00000 - 0x77e27000 C:\Windows\system32\ntdll.dll
0x77e40000 - 0x77f1b000 C:\Windows\system32\kernel32.dll
0x76ef0000 - 0x76fb6000 C:\Windows\system32\ADVAPI32.dll
0x765d0000 - 0x76693000 C:\Windows\system32\RPCRT4.dll
0x76e50000 - 0x76eed000 C:\Windows\system32\USER32.dll
0x76580000 - 0x765cb000 C:\Windows\system32\GDI32.dll
0x76fc0000 - 0x76fde000 C:\Windows\system32\IMM32.DLL
0x76d20000 - 0x76de8000 C:\Windows\system32\MSCTF.dll
0x77140000 - 0x771ea000 C:\Windows\system32\msvcrt.dll
0x77e30000 - 0x77e39000 C:\Windows\system32\LPK.DLL
0x766f0000 - 0x7676d000 C:\Windows\system32\USP10.dll
0x7c340000 - 0x7c396000 C:\Program Files\Java\jre6\bin\msvcr71.dll
0x6d800000 - 0x6da97000 C:\Program Files\Java\jre6\bin\client\jvm.dll
0x74170000 - 0x741a2000 C:\Windows\system32\WINMM.dll
0x76800000 - 0x76944000 C:\Windows\system32\ole32.dll
0x76770000 - 0x767fd000 C:\Windows\system32\OLEAUT32.dll
0x74130000 - 0x74169000 C:\Windows\system32\OLEACC.dll
0x763b0000 - 0x763dc000 C:\Windows\system32\apphelp.dll
0x6d7b0000 - 0x6d7bc000 C:\Program Files\Java\jre6\bin\verify.dll
0x6d330000 - 0x6d34f000 C:\Program Files\Java\jre6\bin\java.dll
0x6d000000 - 0x6d14a000 C:\Program Files\Java\jre6\bin\awt.dll
0x71c80000 - 0x71cc2000 C:\Windows\system32\WINSPOOL.DRV
0x75300000 - 0x7549e000 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6001.18000_none_5cdbaa5a083979cc\COMCTL32.dll
0x76cc0000 - 0x76d18000 C:\Windows\system32\SHLWAPI.dll
0x6d290000 - 0x6d298000 C:\Program Files\Java\jre6\bin\hpi.dll
0x764e0000 - 0x764e7000 C:\Windows\system32\PSAPI.DLL
0x74e20000 - 0x74e5f000 C:\Windows\system32\uxtheme.dll
0x6d7f0000 - 0x6d7ff000 C:\Program Files\Java\jre6\bin\zip.dll
0x70050000 - 0x7020a000 C:\Windows\system32\d3d9.dll
0x75cc0000 - 0x75cc8000 C:\Windows\system32\VERSION.dll
0x71900000 - 0x71906000 C:\Windows\system32\d3d8thk.dll
0x73f90000 - 0x73f9c000 C:\Windows\system32\dwmapi.dll
0x6e560000 - 0x6e568000 C:\Windows\system32\atiu9pag.dll
0x6c970000 - 0x6ccfe000 C:\Windows\system32\atiumdag.dll
0x6c670000 - 0x6c962000 C:\Windows\system32\atiumdva.dll
0x6d1d0000 - 0x6d1e3000 C:\Program Files\Java\jre6\bin\deploy.dll
0x75ec0000 - 0x75fb1000 C:\Windows\system32\CRYPT32.dll
0x76020000 - 0x76032000 C:\Windows\system32\MSASN1.dll
0x76430000 - 0x7644e000 C:\Windows\system32\USERENV.dll
0x76410000 - 0x76424000 C:\Windows\system32\Secur32.dll
0x771f0000 - 0x77cff000 C:\Windows\system32\SHELL32.dll
0x76ae0000 - 0x76baf000 C:\Windows\system32\WININET.dll
0x76e40000 - 0x76e43000 C:\Windows\system32\Normaliz.dll
0x76df0000 - 0x76e35000 C:\Windows\system32\iertutil.dll
0x76fe0000 - 0x77108000 C:\Windows\system32\urlmon.dll
0x6d610000 - 0x6d623000 C:\Program Files\Java\jre6\bin\net.dll
0x77110000 - 0x7713d000 C:\Windows\system32\WS2_32.dll
0x77f20000 - 0x77f26000 C:\Windows\system32\NSI.dll
0x75bb0000 - 0x75beb000 C:\Windows\system32\mswsock.dll
0x75cb0000 - 0x75cb5000 C:\Windows\System32\wship6.dll
0x6d630000 - 0x6d639000 C:\Program Files\Java\jre6\bin\nio.dll
0x6d6b0000 - 0x6d6f4000 C:\Program Files\Java\jre6\bin\regutils.dll
0x6d230000 - 0x6d284000 C:\Program Files\Java\jre6\bin\fontmanager.dll
0x75890000 - 0x75895000 C:\Windows\System32\wshtcpip.dll
0x71460000 - 0x714aa000 C:\Windows\system32\RASAPI32.dll
0x743a0000 - 0x743b4000 C:\Windows\system32\rasman.dll
0x76270000 - 0x762e5000 C:\Windows\system32\NETAPI32.dll
0x711c0000 - 0x711f1000 C:\Windows\system32\TAPI32.dll
0x74f90000 - 0x74f9c000 C:\Windows\system32\rtutils.dll
0x71870000 - 0x71876000 C:\Windows\system32\sensapi.dll
0x75ce0000 - 0x75ce7000 C:\Windows\system32\credssp.dll
0x759e0000 - 0x75a24000 C:\Windows\system32\schannel.dll
0x758d0000 - 0x758f1000 C:\Windows\system32\NTMARTA.DLL
0x766a0000 - 0x766ea000 C:\Windows\system32\WLDAP32.dll
0x76040000 - 0x76051000 C:\Windows\system32\SAMLIB.dll
0x757c0000 - 0x757cf000 C:\Windows\system32\NLAapi.dll
0x75e20000 - 0x75e39000 C:\Windows\system32\IPHLPAPI.DLL
0x75de0000 - 0x75e15000 C:\Windows\system32\dhcpcsvc.DLL
0x76060000 - 0x7608c000 C:\Windows\system32\DNSAPI.dll
0x75dd0000 - 0x75dd7000 C:\Windows\system32\WINNSI.DLL
0x75da0000 - 0x75dc1000 C:\Windows\system32\dhcpcsvc6.DLL
0x735a0000 - 0x735af000 C:\Windows\system32\napinsp.dll
0x73580000 - 0x73592000 C:\Windows\system32\pnrpnsp.dll
0x73540000 - 0x73548000 C:\Windows\System32\winrnr.dll
0x73520000 - 0x73526000 C:\Windows\system32\rasadhlp.dll
0x759a0000 - 0x759db000 C:\Windows\system32\rsaenh.dll
0x10000000 - 0x1000e000 C:\Users\Алексей\AppData\Local\Temp\extension8505230814731185991.dll
0x6bf20000 - 0x6bfeb000 C:\Windows\system32\OPENGL32.dll
0x75050000 - 0x75073000 C:\Windows\system32\GLU32.dll
0x6df90000 - 0x6e075000 C:\Windows\system32\DDRAW.dll
0x74390000 - 0x74396000 C:\Windows\system32\DCIMAN32.dll
0x76950000 - 0x76ada000 C:\Windows\system32\SETUPAPI.dll
0x75090000 - 0x75097000 C:\Windows\system32\atiglpxx.dll
0x69030000 - 0x69df7000 C:\Windows\system32\atioglxx.dll
0x75040000 - 0x75047000 C:\Windows\system32\atigktxx.dll
0x07eb0000 - 0x07eea000 C:\Windows\system32\atiadlxx.dll
0x75700000 - 0x7572d000 C:\Windows\system32\WINTRUST.dll
0x77f30000 - 0x77f59000 C:\Windows\system32\imagehlp.dll
0x6d360000 - 0x6d366000 C:\Program Files\Java\jre6\bin\jawt.dll
0x08660000 - 0x08733000 C:\Users\Алексей\AppData\Local\Temp\extension105815763305391408.dll
0x6d1a0000 - 0x6d1c3000 C:\Program Files\Java\jre6\bin\dcpr.dll
VM Arguments:
jvm_args: -Xbootclasspath/a:C:\Program Files\Java\jre6\lib\javaws.jar;C:\Program Files\Java\jre6\lib\deploy.jar;C:\Program Files\Java\jre6\lib\plugin.jar -Djava.security.policy=file:C:\Program Files\Java\jre6\lib\security\javaws.policy -DtrustProxy=true -Xverify:remote -Djnlpx.home=C:\Program Files\Java\jre6\bin -Dsun.awt.warmup=true -Djnlpx.origFilenameArg=C:\Users\Алексей\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\17\6db71e91-2effb448 -Djnlpx.remove=false -Xmx512m -Djnlpx.heapsize=NULL,512m -Djnlpx.splashport=49255 -Djnlpx.jvm=C:\Program Files\Java\jre6\bin\javaw.exe
java_command: com.sun.javaws.Main -offline C:\Users\Алексей\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\17\6db71e91-2effb448
Launcher Type: SUN_STANDARD
Environment Variables:
CLASSPATH=.;C:\Program Files\QuickTime\QTSystem\QTJava.zip
PATH=C:\Program Files\Java\jre6\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Program Files\QuickTime\QTSystem\;C:\Program Files\Common Files\DivX Shared\;D:\php-5.3.1;C:\Program Files\MySQL\MySQL Server 5.1\bin;C:\Program Files\Sun\JavaDB\bin;"C:\Program Files\Java\jre6\bin"
USERNAME=Алексей
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 6 Model 15 Stepping 11, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows Vista Build 6001 Service Pack 1
CPU:total 2 (2 cores per cpu, 1 threads per core) family 6 model 15 stepping 11, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3
Memory: 4k page, physical 3142344k(1942128k free), swap 6539720k(5477936k free)
vm_info: Java HotSpot(TM) Client VM (16.2-b04) for windows-x86 JRE (1.6.0_19-b04), built on Mar 9 2010 00:48:41 by "java_re" with MS VC++ 7.1 (VS2003)
time: Thu Apr 15 08:54:09 2010
elapsed time: 16 seconds
Posted by Puybaret at Apr 15, 2010, 9:43:59 AM
Thank you. I reported it to Java 3D team. smile
