Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Wrong (Big) Text dimension in menu |
| Print at Sep 24, 2026, 12:24:04 AM | |
| Posted by yawmbox at Aug 15, 2025, 2:51:11 PM |
Wrong (Big) Text dimension in menuI'm using ElementaryOS 8.0.1 (Ubuntu based Linux Distro) Any suggestion? |
| Posted by Keet at Aug 15, 2025, 10:53:35 PM |
Re: Wrong (Big) Text dimension in menu If you have the version from the repository then download the latest version from the download page. You can leave the installed version as is. Edit the launcher and replace the command line with "<path-to-unzipped-download>/SweetHome3D-Java3D-1_5_2-7.5" (the current version is 7.5). If you create a new launcher then use the SweetHome3DIcon.png in the unzipped folder as an icon. First try a different desktop and see if the problem persists. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by yawmbox at Aug 16, 2025, 1:18:16 AM |
Re: Wrong (Big) Text dimension in menu Thank you for your prompt reply. After many attempts, I've decided to switch to Debian 13. With Xfce, everything works as expected without any struggle. ![]() |
| Posted by Keet at Aug 16, 2025, 9:16:33 AM |
Re: Wrong (Big) Text dimension in menu Good choice, I've been using Debian for many years now (Mate desktop). Never had any problem with Sweet Home 3D. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 24, 2026, 12:24:04 AM |
