Print at Sep 9, 2026, 10:02:31 PM
Posted by FabioG75 at Aug 15, 2025, 11:13:50 AM
My project has a room lighter than the other ones
Hello,
I made the project of my house with all rooms in darker mode, in order to use it inside home assistant so that when I light on a light, the room illuminates.
But even if I see into the project all dark rooms, when I save the photo, I get the living room clearer than the others, as if the lights are on but it's not.
Could you help me to understand why?
I'd like to attach the project file but I don't know how to do.
Posted by Keet at Aug 15, 2025, 10:57:46 PM
Re: My project has a room lighter than the other ones
Upload the project file to a file host like mediafire.com and post the download URL here. Make sure you use the "Save and compress" function before uploading, it will result in the same .sh3d file but with a much smaller file size.
Posted by FabioG75 at Aug 16, 2025, 1:34:57 AM
This is the link to my project:
https://www.mediafire.com/file/uefrkiprre0d3od/casa.zip/file
Posted by Keet at Aug 16, 2025, 9:33:35 AM
First of all: you have a single cabinet ("contributions") outside of the house that is huge in object size. Remove it and your project will reduce in size to a tenth of what is is now.
The living room has a single light Sorgente luce bianca in the center that has its power setting still at 100%. It displays as cross in a circle in the 2D view.
Posted by MarioSambol at Aug 16, 2025, 11:21:57 PM
I usually separate the floor plan of the building, the furniture in the individual rooms, the ambient lighting, and the lighting on individual pieces of furniture. In a way that for each part I create a new floor plan on the same level. That way I have the ability to simply hide or show a single level with its associated objects. This is usually my procedure when creating a new project.
Posted by FabioG75 at Aug 17, 2025, 11:33:01 AM
Ok, thanks.
I fixed the issue and now I get the living room as the other rooms.
