Print at Sep 14, 2026, 12:21:51 AM
Posted by f8u9frhjudd at Aug 7, 2025, 2:46:57 PM
confused   Relative Positioning
Hello,
I have an object A and want to place an object be x and y meters relative to it. At the moment I am placing measurement lines and then deleting them afterwards.
Is there a more efficient method?
Thanks
Posted by Keet at Aug 10, 2025, 3:07:19 PM
Re: Relative Positioning
A few possibilities:
Align the object that needs a certain distance at the same position as the source.
1 - Select and move the object with the required distance using the Move function from the AdvancedEdit plugin. This is a plugin that you should install anyway because it has several other basic functions.
2 - Modify the object and adjust the X/Y coordinates with the required distance. This is very easy because every numeric field in Sweet Home 3D is a "calculator". So if you need to move an object 100 to the right you add "+100" after the existing X value. You can do the same for the Y coordinate.
You can use very complex formulas in numeric fields including using parentheses like "(123+(3*21))/2".
Posted by f8u9frhjudd at Aug 10, 2025, 4:02:54 PM
Thank you
