Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: opening the door using AI, video |
| Print at Sep 21, 2026, 3:42:41 AM | |
| Posted by GaudiGalopin3324 at Jun 26, 2025, 10:18:14 AM |
opening the door using AI, video I can't say that it turned out to be easy, I spent several days trying for free. The AI resisted for a long time. This is still not the 100% result I need, but I want to share it with you. I made three renders of the bedroom and one repeat of the last render with the door open, and the dressing room is visible in the open doorway. For a long time, I set the movement of the partition using a text task, but the AI tried to do everything too creatively, other doors appeared and everything opened furiously. I hope this is just a problem of language communication, it's probably possible to ask the question more specifically and correctly. And everything will turn out right. a render with an open door and a view of the dressing room. I did not model the dressing room, I placed a PNG photo on a box with invisible sides, highlighted with a hemisphere. This is a good way to save time if you need furniture layout options, but you don't have time for modeling. It looks like a concept. Video ![]() |
| Posted by GaudiGalopin3324 at Jun 29, 2025, 6:16:08 PM |
Re: opening the door using AI, video The video is corrected, the door opens correctly, almost correctly. ![]() |
| Posted by GaudiGalopin3324 at Jul 1, 2025, 3:20:41 PM |
Re: opening the door using AI, video in the washing machine, you can wash clothes using AI ![]() |
| Posted by GaudiGalopin3324 at Jul 5, 2025, 9:28:23 PM |
Re: opening the door using AI, video I found the right algorithm for opening the partitions. I made three renders with the initial, intermediate, and fully open state of the partitions. In AI, I made two transitions from frame to frame. 1-2 and 2-3. These transitions turned out great. It is necessary to write a text with a mandatory mention of the fixed part and the movable second leaf. Then I combined these two videos into a single block. Watch this Video . all the furniture is made in SH3D of course. The conversation is only about the movement of the partitions. With the help of AI, this is not difficult. I used PixVerse to transition between frames. Everything is free and very fast. ![]() |
Current timezone is GMT Sep 21, 2026, 3:42:41 AM |
