Print at Sep 21, 2026, 3:19:48 PM
Posted by procustex at Jun 8, 2025, 10:21:18 PM
how to add elevation to a wall and make a beam on the roof
Hi, my wall is made as this:
wiev by side
roof
__________
................|beam
................|_____
........................|wall
this format seems that doesn't allow to insert spaces so don't take into account the dots and consider them as spaces
I didn't succeed to insert an image
how can I get this?
Posted by Keet at Jun 10, 2025, 11:08:32 AM
Re: how to add elevation to a wall and make a beam on the roof
To show images: upload your image to an image host like mediafire or imgur and post the url here.
Your drawing is not very clear so show an image to get useful advise.
Posted by procustex at Jun 10, 2025, 2:45:45 PM
ok thanks, this is the figure
https://paste.opensuse.org/pastes/1a09f8246d86
ciao
Posted by Keet at Jun 10, 2025, 4:15:23 PM
I don't see a problem with this. You can create the beam using a box and elevate it so it's flush with the top of the wall.
I assume that the beam is on the outside of the wall and that you want the roof to extend over the beam. It depends on what kind of roof you want but the easiest way is to use the Generate roof plugin to create a roof.
If you don't have that plugin installed, you should install the Plugin Manager (direct download) and use that to install and keep up-to-date other plugins. Read more about it here .
Posted by procustex at Jun 10, 2025, 7:58:57 PM
manythanks, I used miscellaneous>box and it works
