Print at Sep 21, 2026, 4:03:24 PM
Posted by webrehm at May 24, 2025, 10:03:35 PM
Can't create a pdf
I used this program off and on for several years and have never been able to create a pdf. When I try I just get a progress window that never makes a functional file. It does create a pdf file but it is empty and the progress window never finishes.
I am on version 7.0.2
What is going on?
tks
Dennis
Posted by MarioSambol at May 29, 2025, 4:45:33 PM
Re: Can't create a pdf
Try a newer version of the program.
Posted by webrehm at May 29, 2025, 7:27:36 PM
I upgraded to 7.5, still won't create a pdf?? Same exact behavior
Posted by Keet at May 29, 2025, 7:33:44 PM
Creating a PDF is the same as printing to PDF. Instead of using the menu function Print to PDF you can install a PDF printer driver and print to that "printer" with the Print function. There are many (free) PDF printers you can download so if one doesn't work as you like you can simply uninstall it and try another one.
Posted by webrehm at May 30, 2025, 12:11:41 AM
Tried using the microsoft print to pdf on Win 11 but that did not work. Will try a third party version
