Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Transparent Ground outside floor plan |
| Print at Sep 9, 2026, 10:11:41 PM | |
| Posted by Mark3909 at Mar 27, 2025, 9:01:41 PM |
Transparent Ground outside floor planI'm trying to render a floor plan, but have the ground/space outside my floor plan render as transparent. Is it possible to do this natively from SH3D? Here's a sample image online of what I'd like to mimic (the outside shadows around image are nice but not in scope of this inquiry): ![]() |
| Posted by MarioSambol at Mar 27, 2025, 10:24:28 PM |
Re: Transparent Ground outside floor plan Try in the 3D view menu under modify 3D view to put a *.png transparent texture. In that case the ground is completely black in the sunflow render engine. The background remains easy to remove. |
| Posted by Mark3909 at Mar 28, 2025, 5:44:25 AM |
Re: Transparent Ground outside floor plan Awww, thank you for the solution. I would have never known this! I'll have to import it into Affinity Photo to remove the black, but it gets the job done. |
| Posted by Keet at Mar 28, 2025, 8:28:52 AM |
Re: Transparent Ground outside floor plan You can also simply set the background color of the 3D view to a different color. All a photo editor needs is a single color to set as transparent. The transparent texture png does that but a simple color should do the same. The advantage of using a 3D view background color is that you can choose a color that is nowhere used in your project. This avoids that parts in your project also become transparent when you set that color to transparent in the photo editor. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Mark3909 at Mar 28, 2025, 7:46:06 PM |
Re: Transparent Ground outside floor plan @Keet, are there some additional settings needed if you wanted to use a simple solid color as you suggested? When I do that instead of the transparent texture approach the rendering engine will cast shadows and thus make the color delete afterwards a pain. |
| Posted by Keet at Mar 28, 2025, 8:14:03 PM |
Re: Transparent Ground outside floor plan I didn't think of the shadows. Using black (#000000) should avoid that. And you still have the option of using the transparent png if that still doesn't work. Rendering is maybe a lot faster with a black color instead of a transparent png but you can try both options. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 9, 2026, 10:11:41 PM |
