Print at Sep 15, 2026, 5:23:12 AM View all posts in this thread on one page
Posted by sumsine at Mar 24, 2025, 11:25:03 AM
How to create workplaces for my kitchen
Hallo,
can you help me? I want to create worktops for my kitchen with various shapes. How can I do that?
Thanks a lot
Sabine
Posted by Keet at Mar 24, 2025, 6:08:25 PM
Re: How to create workplaces for my kitchen
You will have to be a little more specific.
For simple tops you can resize a box. Use a stretched cylinder for a rounded border.
On my site under Kitchen2 there is a small library with replacement noses for kitchen tops that you can use. Or you can download the shapes library that has half cylinders and objects for the corners.
For random shapes the easiest way is to use a room. Draw and curve walls for the outside of the worktop you want. Double click inside to create a room. Select and export only the room, import it and adjust the height to what you want.
Posted by MarioSambol at Mar 25, 2025, 11:44:59 AM
Creating an object using a created room is a very creative way. I'm surprised, I usually used some other software to do this. Apparently there is no need for that.
