Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: The order of my Levels seems to be locked - Why? |
| Print at Sep 15, 2026, 7:19:27 AM |
| Posted by peng1 at Mar 16, 2025, 5:22:59 AM |
The order of my Levels seems to be locked - Why? I am working with a model that has several (11) 'levels'. for some reason I am no longer able to adjust the order of these levels using the up/down arrows in the 'Modify Level' dialog. A few days ago I was able to move a level from top to bottom but now all levels seem to be stuck. I can still adjust the order of levels in my old files and also with a new file but this particular file seems locked. File size is ~20MB. Note that all my levels are at the same elevation, height and floor thickness. I am therefore using levels as 'layers' rather than traditional levels. Any ideas? My next step is to start again with a new file and copy each layer into that but I'm interested to know what has gone wrong with this file. |
| Posted by hansmex at Mar 16, 2025, 7:49:29 AM |
Re: The order of my Levels seems to be locked - Why? In version 7.5 I created 13 (empty) levels and was able to move the selected level up and down. Check your version and update if necessary, then try to make 11+ empty levels before copying everything to a new file. ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by JonnyD at Mar 16, 2025, 8:05:19 AM |
Re: The order of my Levels seems to be locked - Why? After over a decade of using SH3D I had no idea you could do this! 😂 |
| Posted by hansmex at Mar 16, 2025, 9:33:05 AM |
Re: The order of my Levels seems to be locked - Why? Little secret.... me neither (after 15+ years) ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by JonnyD at Mar 16, 2025, 10:22:22 AM |
Re: The order of my Levels seems to be locked - Why? Us old dogs eh? 😂 |
| Posted by Keet at Mar 16, 2025, 12:26:20 PM |
Re: The order of my Levels seems to be locked - Why? Little secret.... me neither (after 15+ years) It's only been available for a "short" time... almost 10 years or so ![]() ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by JonnyD at Mar 16, 2025, 1:13:36 PM |
Re: The order of my Levels seems to be locked - Why? Just goes to show you find new things all the time. |
| Posted by dorin at Mar 16, 2025, 1:27:56 PM |
Re: The order of my Levels seems to be locked - Why? Like other colleagues here, I have tried to reproduce your problem (16 levels at same elevation). No success!. The problem is serious and deserve attention. My suggestions: 1. Save the file as a different one name (as a backup) and try again. Sound illogical but it is a test. 2. Inform us about SH3D version and OS. 3. If you trust us share the file here to study it. Some of us will find the problem. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by MarioSambol at Mar 17, 2025, 10:35:53 PM |
Re: The order of my Levels seems to be locked - Why? I have been using multiple levels for a long time as layers of the same height and elevation. Usually a maximum of 5 layers, usually first for plan, second furniture, third for light ambient, fourth for light. That way I can easily hide or reveal levels and select objects in the scene. I have had no problems because the order doesn't matter to me, the only thing that matters to me is the hide or show option. |
| Posted by peng1 at Mar 19, 2025, 11:59:43 AM |
Re: The order of my Levels seems to be locked - Why? Thanks all for your inputs. Sorry for slow reply but I got busy. I am using V7.5 on windows 11 64bit. 16G of RAM. I spent some time tonight and created a new file and copied all my level contents from the 'stuck' file to this new file. The new file seems to be behaving correctly, ie I can freely manipulate the levels up and down. So it is looking like my original file is somehow corrupted and for now I am back up and running. If I find some time I may dig a bit deeper into that old file, deleting layers etc to see if it comes right. I am reminded that I have recently (months?) started getting SH3D crashes with symptom of CPU/fan ramping up but the UI stops responding and I have to kill the process. Thankfully SH3D does provide file recovery however I wondeer if one of those crashes has corrupted the file? (or vice-versa). Note that I am using the levels feature for more than just as 'layers', in addition I am using levels to create 'versions' of a design. So I create a level and copy-paste the previous level contents and then edit the new 'level' [version] from there. Some of the plan levels can be quite busy but I do delete old/uneeded levels to avoid file size getting to out of hand. But probably I am just stretching my SH3D/PC system beyond it's limit. Note also that the reason I might want to change the order of levels is because of strange (and annoying) artifacts* that I see in the plan view that happen with doors when they are positioned close to another wall in a level of lower order, even when that 'lower' level is tagged as not viewable.. Snapping is also affected in a simlarly way. (*I would add an screenshot of the artifact if I knew how to add images in this editor!). |
Current timezone is GMT Sep 15, 2026, 7:19:27 AM |
