Print at Oct 6, 2026, 12:07:26 PM
Posted by Carrock at Feb 5, 2025, 8:18:27 PM
Vertical start a wall above ground, how?
Hi all
Anyone knows how to move a wall up?
What i need to do is to create the triangle in the top above a window when the wall below is not full height.
Below you can see the wall is not full height, but how do i then add a wall on top that covers the area above the window?
Thanks
Posted by hansmex at Feb 6, 2025, 11:20:10 AM
Re: Vertical start a wall above ground, how?
1 - split the wall in two parts, and make both parts sloping
or
2 - insert a triangle
or
3 - insert a level with the correct elevation where you put a wall, split the wall in two parts, and make both parts sloping
Posted by Carrock at Feb 6, 2025, 9:24:12 PM
Great, thanks
Adding a new level with a modified height made it work.
