Print at Aug 7, 2026, 10:18:24 AM
Posted by gnarf at Feb 4, 2025, 9:31:53 AM
Multiple sloped wall with window
I also have a room with two different slopes on the outside wall, which also has a window. I absolutely can't figure it out. I've attached a (not so good) photo, maybe you can help me. THANKS!
[img][/img]
Posted by selfbuild01 at Feb 6, 2025, 8:12:10 PM
smile   Re: Multiple sloped wall with window
My space has only 2ft high wall before it begins the roof slope. There are 3 velux on one side and 2 french dormers on the opposite slope. I've tried a few different ways but haven't mastered it it. If anyone can help I would really appreciate some clear instructions.
Thanks
Posted by Keet at Feb 6, 2025, 8:43:28 PM
Situations with these kinds of sloping walls are unique for each project. There is no generic solution for this, usually the slope is the bottom/underside of the roof you add.
If you want the slope independent of the roof you can use a thin box that you tilt and elevate. A thin box can close a sloping space without sticking out on the outside. Make all sides of the box invisible except the one that you see as the slope.
You can also use a triangle and make all sides except the slope invisible. Rotate and elevate as needed. The effect is the same as with a box.
