Print at Oct 5, 2026, 10:30:34 PM
Posted by audiophilone at Jan 18, 2025, 4:29:15 PM
Problem with saved camera position and zoom!
Hello, when i click on my saved camera position...the position appears but not with the correct zoom?
where is the problem?
i think i got this problem since i installed Pan 3d view plugin
any ideas?
greetings!
Posted by Daniels118 at Jan 20, 2025, 5:56:24 PM
Re: Problem with saved camera position and zoom!
Please try to remove the plugin and check if the problem persists and then report it here.
Posted by audiophilone at Jan 23, 2025, 8:46:55 PM
@daniels118 after i removed the plugin the zoom work now correctly. but now i got a nother problem after removed the tool.
befor i removed and after...
@daniels118
what is wrong with the light?
Posted by Daniels118 at Jan 24, 2025, 8:46:44 PM
I know this may sound absurd, but I can assure that Pan3dView plugin doesn't affect the model anyway, the best chance is that you have moved the lights on the floor by mistake. Please check that the lights are at the proper elevation. If you don't feel confident with the elevation field, you may also try the View light sources plugin.
BTW the first problem you reported is weird, I have no problem with Pan3dView and stored camera positions. Are you using the latest version of SH3D and Pan3dView? Is SH3D the installer version or one from the stores? On which platform?
If you want to spend some time helping me to improve the plugin, please try to reproduce the problem while collecting the logs as described here:
https://www.sweethome3d.com/support/forum/viewthread_thread,9906#46443
and post the content of the log file here.
If you can't get the logs with the above method, you can try this one:
https://www.sweethome3d.com/support/forum/vie...read,5072_offset,30#53691
Posted by MarioSambol at Feb 15, 2025, 12:10:30 PM
From my own experience, I avoid any plugins to perform some actions. As far as I know, SH3D is an open source program and so are the plugins written for it. Far more advanced and terribly expensive 3D programs also have their own plugins that can cause problems. I think that's why it's better to use the capabilities of the program itself without adding plugins, because every hardware configuration is different and there will always be situations when it won't work well.
Posted by Keet at Feb 15, 2025, 12:32:38 PM
True, but most plugins for Sweet Home 3D add features that are not available in the base program. It's either do without or use the plugin. I use multiple plugins and have encountered very few problems with them.
Posted by nckv at Jan 2, 2026, 3:46:48 PM
Just a heads up that I also have this problem, completely reproducible. The zoom level is always zoomed out a bit when the Pan3d plugin is installed.
