Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Critical error in 3D rendering with Linux and Nvidia driver (v7.5) |
| Print at Sep 23, 2026, 1:30:18 PM | View all posts in this thread on one page |
| Posted by wsky at Oct 17, 2024, 11:44:17 PM |
Critical error in 3D rendering with Linux and Nvidia driver (v7.5) Hi there, I can not start Sweet Home 3D with the standard script, only getting an error message about a critical error in rendering system and I should update the graphics driver, then it quits. However it's the latest driver that is currently available on Ubuntu 24.04 which is Nvidia driver 550.107.02 I can use the other script "SweetHome3D-Java3D-1_5_2" to start Sweet Home 3D and it seems to work fine. Here is the shell output from the normal start script: Failed to load module "canberra-gtk-module" |
| Posted by Keet at Oct 18, 2024, 2:58:40 PM |
Re: Critical error in 3D rendering with Linux and Nvidia driver (v7.5) On Linux always use the "SweetHome3D-Java3D-1_5_2" script. I use it on Debian. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by scjo at Oct 26, 2024, 1:51:55 AM |
Re: Critical error in 3D rendering with Linux and Nvidia driver (v7.5) wsky, I'm late. Could you meanwhile sort it out? If so: was it Keet's suggestion or another solution? Emmanuel Puybaret suggested an additional java parameter: -Dcom.eteks.sweethome3d.j3d.version=1.5.2I'm using nvidia, too. The only thing that helped me was a switch from the proprietary driver to the open source nouveau (see link above). However, nouveau is not the greatest driver either due to nvidia's denial of support. I'm cured from nvidia. ---------------------------------------- Cheers - Joe // |
| Posted by wsky at Oct 26, 2024, 2:34:49 PM |
Re: Critical error in 3D rendering with Linux and Nvidia driver (v7.5) Hello scjo, starting Sweet Home 3D from shell like this? ./SweetHome3D -Dcom.eteks.sweethome3d.j3d.version=1.5.2This doesn't work, it will open the splash screen and then does nothing until I send Ctrl-C to the process. For now, I am always using "SweetHome3D-Java3D-1_5_2" to start. And also I am waiting for the Nvidia driver 560 or later to be available with the driver updater on Ubuntu 24.04. Currently 550 is the latest available but I had 560 on Ubuntu 22.04. Furthermore, I'm using the "open" Nvidia driver 550 though the proprietary driver 550 is shown as recommended. I haven't tested yet if Sweet Home 3D (standard starter) works with the proprietary driver. |
| Posted by scjo at Oct 28, 2024, 1:47:19 AM |
Re: Critical error in 3D rendering with Linux and Nvidia driver (v7.5) In your command, SweetHome3D is probably a shell script. Open it with any text editor, and find the "exec" line. Mine starts with: exec "$PROGRAM_DIR"/runtime/bin/java My java knowledge is very limited, I don't even know if the sequence of parameters matters. But it won't hurt either. HTH ---------------------------------------- Cheers - Joe // |
Current timezone is GMT Sep 23, 2026, 1:30:18 PM |
