Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Programmatically Changing Openings |
| Print at Sep 10, 2026, 12:53:27 AM | View all posts in this thread on one page |
| Posted by shmuelzon at Sep 28, 2024, 7:18:04 PM |
Programmatically Changing Openings Hey, As a part of a plugin development, I want to close a door/window in the floor plan. I tried following the code that does this from the UI and my understanding is that modifying the piece of furniture's transformations (hinges and whatnot) also alters its overall dimensions and so, after transforming it, i.e., removing the existing transformations, I need to recalculate the size and position and update the piece of furniture accordingly. I tried to, basically, copy-paste the code from the ModelPreviewComponent class but I guess I'm missing something since, while the door does close, it stays at, more-or-less, the same original dimensions and becomes distorted. In my code, I find the relevant furniture by traversing home.getFurniture() and, when needed, call a new shutTheDoor() function I created: private void shutTheDoor(HomeDoorOrWindow furniture) {These are the old and new bounds, as printed from the above: oldBounds: Bounding box: Lower=492.4598841340258 0.0 -2029.357666015625 Upper=583.4937291472243 208.5 -1943.9011759098528As can be seen, they are very similar. If it helps, the position and dimensions of the door when it's open (the starting state) is: X= 538, Y= -1986.6, Elevation= 0, Angle= 270, Width= 85.5, Depth= 91, Height= 208.5When closing it via the "Modify openings..." UI, the position and size become: X= 507.5, Y= -1982.6, Elevation= 0, Angle= 270, Width= 77.3, Depth= 30.9, Height= 208.5However, closing it with the above code, results with: X= 537.8, Y= -1986.6, Elevation= 0, Angle= 270, Width= 91.5, Depth= 85.5, Height= 208.5Can anyone please point me in the right direction for how to properly close (and later restore) doors/windows? Thanks in advance! |
| Posted by Daniels118 at Sep 29, 2024, 9:56:31 AM |
Re: Programmatically Changing Openings I have interest on this subject, so far I've been able to open doors in the 3D view, but I wasn't able to find a way to consolidate the changes in the plan. If this is enough for your use case, you can have a look at the source code of the Pan3dView plugin. There is also a video on my YouTube channel which shows the feature in action. |
| Posted by shmuelzon at Sep 29, 2024, 12:42:45 PM |
Re: Programmatically Changing Openings I wasn't able to find a way to consolidate the changes in the plan What do you mean by this? That the openings are only changed in the 3D view but nothing is changed in the plan? In my case, it changes both the plan and the 3D view but the door/windows become distorted because their proportions don't match anymore. If this is enough for your use case, you can have a look at the source code of the Pan3dView plugin I need this change to be applied when rendering an image. I think that a new scene is built for the renderers and not using the same objects in the 3D view but I might be off here. If I am, then it might be enough to only modify the 3D view and leave the plan intact. |
| Posted by Keet at Sep 29, 2024, 2:11:24 PM |
Re: Programmatically Changing Openings In my case, it changes both the plan and the 3D view but the door/windows become distorted because their proportions don't match anymore. Your problem might be related to a bug I reported with wrong deformations in the 3Dview with the Pan3DView plugin: http://www.sweethome3d.com/support/forum/view...ead,5072_offset,100#61531One thing I figured out that might help you with finding the cause is to place an object horizontal and one diagonal and see the difference in how the deformations show. You will also have to check chained deformations (deformation on a deformed part). ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by GeoffS at Sep 29, 2024, 2:47:41 PM |
Re: Programmatically Changing Openings My observations have found that a door opened with the Pan3DView plugin will not render open. A cupboard with 2 doors, the left opened in the Modify Deformations Dialog and the right door opened with the Pan3DView plugin will render with the right door closed. |
| Posted by GeoffS at Sep 29, 2024, 2:59:40 PM |
Re: Programmatically Changing Openings In all fairness to Daniels118 his plugin does state that the Edit openings is beta and the option to have access to this feature in its infancy is greatly appreciated. |
| Posted by Keet at Sep 29, 2024, 3:12:27 PM |
Re: Programmatically Changing Openings In all fairness to Daniels118 his plugin does state that the Edit openings is beta and the option to have access to this feature in its infancy is greatly appreciated. Correct. That's why I stated in a follow-up post that's it's no problem, no hurry to fix. I mainly use the 3Dview deformations to test that deformations work. That they are distorted with wrong deformations is no problem as long as I can see that they work in the order they are supposed to.---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by shmuelzon at Sep 29, 2024, 4:13:01 PM |
Re: Programmatically Changing Openings My observations have found that a door opened with the Pan3DView plugin will not render open. A cupboard with 2 doors, the left opened in the Modify Deformations Dialog and the right door opened with the Pan3DView plugin will render with the right door closed. Thanks for that, then I need to make it work in the plan... |
| Posted by shmuelzon at Jul 8, 2025, 9:33:56 PM |
Re: Programmatically Changing Openings The feature request for my SH3D plugin requiring this functionality was recently brought up again and I, needing some kind of win, decided to try and tackle it again. I'm not sure everything below is required but I tried to only include things that made sense to me. I did have the basic idea of what needs to be done correct, just not the way to do it :) The gist of it is to: Here's the functional, though not that pretty, code to do that: |
Current timezone is GMT Sep 10, 2026, 12:53:27 AM |
