Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Rendering |
| Print at Sep 10, 2026, 1:44:59 AM | |
| Posted by leonidas187 at Sep 23, 2024, 6:07:14 PM |
Rendering Friends, can we install rendering engines other than yafaray and sunflow in sh3d? If we can download it, where and how can we do it? |
| Posted by sjb007 at Sep 23, 2024, 11:54:26 PM |
Re: Rendering Nope. Another renderer requires export/import to another application, unless someone tackles the significant job of adding another renderer to SH3D. |
| Posted by Keet at Sep 24, 2024, 12:03:11 AM |
Re: Rendering I looked into this and like sjb007 says it's a significant job. I stopped looking into options when it was clear that it wasn't going to be much use anyway because Sweet Home 3D only supports a limited set of material properties. For example, you can only have a single texture mapping (map_Kd) but none of the other mappings. If you really need a special rendering export it to Blender and in Blender add all the extra material properties and texture mappings. Then render with one of the renderers supported by Blender. The only thing that would justify another renderer in Sweet Home 3D is one that uses the GPU instead of the CPU that both current renderers use. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by leonidas187 at Sep 24, 2024, 3:33:32 AM |
Re: Rendering Thank you both very much. |
Current timezone is GMT Sep 10, 2026, 1:44:59 AM |
