Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Artifacts on imported models in plan view |
| Print at Sep 29, 2026, 4:32:42 AM | View all posts in this thread on one page |
| Posted by lybin at Aug 26, 2024, 9:10:19 AM |
Artifacts on imported models in plan view Hello. Previously, imported models displayed without errors. I don't know if it's related, but after importing this pool, all imported models started showing artifacts. https://www.sweethome3d.com/models/scopia/swimming-pool.zip ![]() I cleared the following directories, but nothing helped: ~/.eteks ~/.java/.userPrefs/com 7.4 and 7.5 versions as well OpenJDK version 1.8.0_422 - 64bit - 0.1 / 0.9 GB provided by Arch Linux Java 3D version 1.5.2 - NATIVE_OGL PDF Operating System: Arch Linux KDE Plasma Version: 6.1.4 KDE Frameworks Version: 6.5.0 Qt Version: 6.7.2 Kernel Version: 6.10.6-zen1-1-zen (64-bit) (linux-lts 6.6.47-1 the same) Graphics Platform: Wayland Processors: 16 × AMD Ryzen 7 PRO 7840U w/ Radeon 780M Graphics Graphics Processor: AMD Radeon 780M |
| Posted by Puybaret at Aug 26, 2024, 7:27:51 PM |
Re: Artifacts on imported models in plan view Sometimes the icon created at the end of furniture import wizard isn't correct. As it's actually a screenshot, ensure that the wizard is at screen during the last step and don't click on Finish button too fast. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by lybin at Aug 27, 2024, 8:26:42 AM |
Re: Artifacts on imported models in plan view Hello, Emmanuel. Thank you for the answer. I've tried 2 times as you said and no luck. https://drive.google.com/file/d/18-4L_LTHEuEM...jvfFnmXg/view?usp=sharing |
| Posted by Puybaret at Aug 27, 2024, 9:46:14 AM |
Re: Artifacts on imported models in plan view Could you try with the official release of Sweet Home 3D (try SweetHome3D and SweetHome3D-Java3D-1_5_2 included scripts)? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by lybin at Aug 27, 2024, 11:11:15 AM |
Re: Artifacts on imported models in plan view the same behavior ![]() |
| Posted by Puybaret at Aug 27, 2024, 12:07:17 PM |
Re: Artifacts on imported models in plan view Not sure I can do better. But you could at least select Top view option in preferences to get nicer drawing in the plan. If the option is greyed, run the other command to launch Sweet Home 3D. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by lybin at Aug 28, 2024, 7:52:47 AM |
Re: Artifacts on imported models in plan view I've install newer jre-openjdk 22, it was 8. ![]() On the first try the app requires sharing screen and stucks. If to kill and try import again it success. ![]() lev@lybin ~ $ sweethome3d Maybe it's related to Wayland? What the Java version is preferred? I can adjust the package in Archlinux. |
| Posted by Puybaret at Aug 28, 2024, 10:19:12 AM |
Re: Artifacts on imported models in plan view You don't need to install any Java version. The official release comes with its own copy of Java runtime. It's normal that the system ask you to authorize sharing screen in Sweet Home 3D because the icon created for an imported furniture is actually a screenshot, as said before. Generating this icon from an offscren 3D image would be nicer, but there are some cases when offscreen imaging is not available. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by lybin at Aug 28, 2024, 11:23:22 AM |
Re: Artifacts on imported models in plan view Got it thanks, but the official release doesn't work for me. > It's normal that the system ask you to authorize sharing screen I think this bug is really related to Wayland, because there're a changes about screen sharing in it. Don't know why it worked earlier. |
Current timezone is GMT Sep 29, 2026, 4:32:42 AM |
